Dodge Dakota Engine Noise
Need help! I recently purchased a 2006 Doge Dakota with a 3.7 litre V- 6 engine with 17,000 miles. There is a ticking sound coming from under the plastic manifold on top of the engine at idle. Does anyone know if this is normal or some kind of valve tap? Also, the engine seems to wonder in RPM's like a variable idle speed...not much, but enough to hear and see it on the tach as the needle just hovers a little above and below 700 RPM. Any input would be appreciated.
However, that doesn't mean there aren't exceptions. Based on your report I'm momentarily at a loss to make a guess, though, because the lifters and rockers are in the cylinder head and there is no center camshaft below the intake manifold. How is the oil pressure? Are you using the correct oil (5W30) and the correct oil filter? Does the noise vary with engine temperature or some other condition?
I'd try to get a hold of a stethoscope and search for the noise.
Dusty
Best regards,
Dusty
I'm going to bring the truck back to the dealer in the next couple days so they can hear it.
They just replaced the exhaust from the Y pipe back because they said someone had improperly installed an after market exhaust. It looks to me they installed a new pipe back from the Y to the rear muffler and a new tail pipe. What I found to be suspicious is they left out the front muffler. At least I think there is supposed to be a front muffler. This is one of those Dodge certified used trucks. What I don't understand is why this was not picked up in the precertification inspection. I'll let you know what they say.
Thanks, Ted
Ted
Best regards,
Dusty
I have heard some that sound like diesals when first started after they had sat for a while...and it goes away after a minute or so.
But Im not sure the 3.7's have the valve lashers... I have never heard one tick.
