Chevrolet Monte Carlo Heat and AC Problems
when should compressor run? Mine runs when controll is on floor .
Heating controls some settings don't work (no fan control).
changed ACDELCO Part # 1580571 about $30 (OK now)
Rear defrost not working.
Soldered the wire back on the rear window grid (OK now)
Wipers parking wrong
Bent a tab down on the wiper motor assembly (OK now)
Wiper had no intermittent functions or low speed.
I changed a diode, you can also but pulse module (OK now)
No A/C, low/high beams come on and stay on when started, security light on(car starts fine), keyless entry not working, headlights turn off while driving (whenever), ...Replaced the BCM (ok now)
turn signal not working Resoldered the hazzard switch (ok now) you can also relpace the switch
thansmission shifting bad, then lost some gears (replaced shift module (ok now)
I still like this crap wagon 100,000 + miles
Don't get fooled
if you have 12v i would test the ohms on the rear grid with on wire off......it should not read open.
