2002 Trooper - 12V Plug is not working in both front and back
dejajitdejajit Posts: 9
edited April 2014 in Isuzu
I am original owner of 2002 Trooper. This SUV has been a very dependable vehicle for last 7 years but I have a small problem now.
12V Plug is not working in both front and back. I am not sure if this is something that would be covered under Isuzu's 10 yr warranty.
Please help me debug.
  • tidestertidester Posts: 10,059
    What have tried running off the plugs and did you test the plugs with a volt meter?
    SUVs and Smart Shopper
  • dejajitdejajit Posts: 9
    I tried a car vacuum in another car and it worked. It does not work in my trooper.
    Also my GPS charger does not work.
    No, I did not try with a volt meter. I don't have one.
    In that case, either the plugs aren't wired up properly or both fuses have been blown. If they had worked previously then check out the fuses.
    It was the fuse. Thanks a bunch!
