Nissan 370Z
This topic is for discussing the Nissan 370Z.
Also, after reading Dan Edmunds' writeup about brake caliper placement I've been taking mental notes everywhere! I just noticed today that the 370Z has brake calipers in front, indicating rear tie rods (idler arms?). For a vehicle so dynamically praised and purpose built it seems like a really odd engineering move. Did they deploy some tricky engineering placing both the huge brake calipers and the steering gear out front?
The hunt for a new car goes on! BTW, the seats in the Genesis Coupe are over-bolstered too!!
:lemon:
Let me make anyone that's interested in purchasing a new NISSAN 2009 370Z aware of a major problem with this car.
IT MUST HAVE AN ENGINE OIL COOLER! The car, without an ENGINE OIL COOLER, is not a very poor performance car. As matter of fact, the car is a real disappoint!
If you can only drive the car at low engine RPM's, which would be anything below 3000 RPM's, for short periods, then purchase a 370Z.
I purchased a new 2009 NISSAN 370Z on February 26, 2009, and the car only has 620 miles on it.
I've been contacting NISSAN CONSUMER AFFAIRS DEPARTMENT, WHAT A JOKE, regarding having the 370Z checked for high ENGINE OIL TEMPERATURE. I was instructed to take it back to the original NISSAN DEALERSHIP where I purchased the car, which is CRONIC NISSAN, located in Griffin, Georgia, for the NISSAN DEALERSHIP to VERIFY that my 370Z has an ENGINE OIL TEMPERATURE PROBLEM. Well, after it was verified that my car did have a ENGINE OIL TEMPERATURE PROBLEM, I was advised that I would have to take it to another NISSAN DEALERSHIP, and have it checked again. All of this has been going on for over three months.
I'm advising all potential customers that are interested in purchasing a new 2009 370Z CAR, to ensure that it has an ENGINE OIL COOLER INSTALLED on it prior to making a purchase.
AS FOR NISSAN's CONSUMER AFFAIRS DEPARTMENT, I MUST SAY, WHAT A JOKE!
Is the aftermarket jumping on this?
I disagree, because you can't drive any 2009 370Z car over 3500 RPM's, when the ambient temperature is over 90 degrees, for more that 25 miles without the Engine Oil Temperature climbing to above 270 degrees. If the 370Z's Engine Oil Temperature reaches 280 degrees, the car's max RPM's will be reduced from 7500 RPM's to 6500 RPM's, and if the Car's Engine Oil Temperature reaches 290 degrees, the car's Engine max RPM's of 7500, will be reduced to 4500 RPM's. That is approximately one half of the 370Z available HORSE POWER.
Now, tell me if you thing Nissan has a major problem with the 3.7L Engine?
If you read their advertising they more or less all claim superiority over the competition.
Frankly I don't know if there is a great of amount of difference except conventional oils have a higher pour point at lower tempertures after reading a published article that claimed oil comparisons, both conventional and synthetic vary only very slightly on long term New York City taxis using a controlled test spanning many thousands of miles over a full years span.
It makes one wonder although the tests did not include high speed track racing.
I guess the same applies to oil filters as well.
Your thoughts will be appreciated.
R M H
Kind of makes me wonder why my 370z only indicates about 200 to 220 degs. on long mountain grades with outside temps hovering in the 80's???
Perhaps it's because I didn't intend to run my car to death but just enjoy it's wonderful handling and acceleration in the mountains of Pennsylvania.
They certainly don't give these things away you know.
R M H
R M H
Chintan
Corporate Communications
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
