Have you recently used your tax refund (or are you planning on using your tax refund) toward the payment of a new or used vehicle? Or, are you planning on using your tax refund toward any expenses related to your car?
If so, a reporter would like to talk to you. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Are you the parent of a generation Z child (born in the mid-1990s to the early 2000s)? Do you have differing opinions on the importance of buying a car, what types of vehicles you're interested in, or just how you view cars in general? If so, a reporter would like to speak with you and your child. Please reach out to [email protected] by Friday, January 25 and the Edmunds PR team may connect you with the journalist.
Toyota Venza Transmission Problems
2
  • wwestwwest Posts: 10,706
    Maybe it's an effort to eliminate the "snow" button/mode, if you can "command" a start-out in 2nd or 3rd.....
    So what's wrong with a "true" manual mode...??
    Plus there are times you might not wish to inadvertently encounter the level, sometimes hazardous level, of engine compression braking on the front drive wheels that might result from an "automatic" downshift.
  • I wonder if anyone has a similar problem ?When I leave my 2009 Venza parked and not used for more then 3 weeks, the battery goes dead and I have to ''boost'' it to get it started. The dealer says that this is because there are so many electronics on the car that even with everything off the battery will drain out completely. He suggested I use a trickle charger or disconnect the battery if I leave it not used for more then 3-4 weeks; have never had this with any other cars, I am curious if anyone else has run into this, the 6 cylinder Venza has 8000 km on it and has been ''completely'' gone over by the service dept at the dealer
    many thanks
  • now that you've mentioned it, I'll pay more attention to my venza...coincidently, my transmission slips often inbetween 1st , 2nd and 3rd gears..be on the lookout! I;m calling the dealer tomorrow.
  • now that you've mentioned it, I'll pay more attention to my venza...coincidently, my transmission slips often inbetween 1st , 2nd and 3rd gears..be on the lookout! I;m calling the dealer tomorrow before i get killed when the car revs in between gears.
  • 'hill hold?' mine rolls .......now that you've mentioned it, I'll pay more attention to my venza...coincidently, my transmission slips often inbetween 1st , 2nd and 3rd gears..be on the lookout! I;m calling the dealer tomorrow
  • joe281joe281 Posts: 2
    We bought a new Venza a couple of weeks ago. We left the car in a parking lot while we took a week long cruise. The battery was dead when we got back. It took the parking lot attendant quite a while using his bus and his jumper cables to finally charge it enough so we could get it started. We have a V6 with all the bells and whistles. We couldn't even open the back door to get to the jumper cables because there wasn't enough power. And, we couldn't open up the trunk compartment from the inside. We had an 8-hour drive back home and didn't have any further problems. We haven't been to the dealership yet, but we will very soon. Have you learned anything else?
  • nilkitwanilkitwa Posts: 5
    had the same problem with exactly the same kind of Venza, see my previous post, discussed this with my dealer it seems that the car's electrical system drains to nothing if left unattended for more then 10 days; a bit of a problem for a 2 week + canoe trips or a 3 week + plane holidays, anyways for 60 dollars he put a ''kill'' switch on the battery which turns off the entire electrical system to the car, hopefully this resolves the problem - hope this helps, I will be really upset if I'm looking for a ''boost'' at the float plane base in Inuvik at the end of a holiday trip
    Thanks for the info. That's helpful to know there's a work around. However, it seems to me that Toyota ought to foot the bill and put these switches on the cars with this problem. After spending all that money on the car, I shouldn't have to pay any more to have it work as it should. I'll keep you posted on how it works out.
  • bobbycybobbycy Posts: 1
    Exact same problem happened to my 2009 6-cyl Venza (mileage = 5,500 kilometers) in mid April after leaving it parked in the garage for 10 days. The battery was compeletly discharged. Required boosting through Roadside Assistance. Drove it to the dealership. They did a "battery load test" and gave the battery a clean bill of health. They probably dismissed the incident as another case of "owner incompetence" - I could tell from the service department personnel attitude when they asked insulting questions like: "Are you sure you didn't leave any lights on?" I suspect the incident rate will pick up soon. I'd encourage you to write Toyota so they can start tracking the problem seriously. I will be writing my letter shortly.
  • carync1carync1 Posts: 4
    I may have an advantage on other Venza owners. My 2009 4-cyl. AWD Venza, purchased 6 months ago, has just turned 40,000 miles!
    For the past several weeks, the automatic transmission has been "shuddering", and even the occasional "clunk" when shifting between gears.
    I drive quite conservatively in order to maintain about 27.5 mpg., since I drive so much.
    I took the car into Fred Anderson Toyota in Raleigh at 36,000 miles ... and they told me that the car was "within factory specs"!
    Are you kidding me? Factory specs ??? Sounds more like an Insurance Adjuster trying to save Toyota money rather than stand behind the product!
    The noise is so bad now that it sounds like I'm going over bumps in the road (when I'm on perfectly smooth asphalt, and passengers comment about the noise.
    This is all too reminiscent of the Sienna Transmission debacle.
  • I am considering a 2011 VEnza. Have the dead battery and transmission issues been resolved. I would like to hear from 2011 owners. Thanks. RR70
  • Not resolved-had a switch installed to disconnect battery to car but this messed up the electronics causing the car to blow fuses and entailed towing the car 350 km to the closest Toyota dealer from Alaska all resolved and dealt with very properly but ''a bit of a hassle factor!'' Now I have a dedicated wrench and I just disconnect battery from engine when parking it for more then 3 weeks not a big deal takes about 3 minutes. Otherwise have been driving to work on the Alaska border all this winter and the car has handled exceptionally well in snow to the ''gunales'' ice and ice ''ridged '' high speed hwy driving ,car goes like a ''bomb'' when needed, tracks well and am very happy with it. Deep snow slush ice all has been good have little comment on city driving since this is not in my lexicon. The Toyota dealership here in northern B.C. has treated me exceptionally well and I guess that's what it's all about, hope this helps.This battery drainage with any prolonged parking seems to be a problem in most new ''electronically dependant'' vehicles.
  • thanks for your reply. the easiest way to solve the battery drain problem is to purchase a screw style battery disconnect switch. this is what I used on my show car. it should not cause a problem with fuses etc, since its just the same as disconnecting the battery cable.
    it sure sounds to me like there is a parasitic drain in this car. toyota needs to fix it.
    i will still consider the car, but less so, and with more healthy distrust. rr70
    Every time you disconnect the battery all of the engine/transaxle control parameters, LEARNED parameters, will revert to the factory default parameters. Now, until the "REAL" operational parameters can be relearned (200-1000 miles) the engine control parameters and transaxle shifting patterns will be less than optimal. In the meantime the shift pattern will often be enough different to be quite noticeable.
  • ABS are simply brakes that apply and disengage and are controlled by the ECU ( a computer ) to make stopping safer. You have a Camry, are you still alive ? The ABS brakes are not a new thing not unlike air bags, both of them killed a lot of people when they first came out. They should not really make any sound but the disc brakes could if they were not installed right or are out of OEM specs. Don't waist your money on the organic pads just get the higher priced kind. ABS brakes can't lock up as you will feel the pedal move when applied. I've had cars with out ABS and once had to make a fast short stop,
    the Dodge Charger (1968) made it happen for me as the car locked up and if I had ABS I would have hit the car in front of me. It was a multiple car accident
    and my Charger was the only one to drive away untouched. Air bags and ABS are things that engineers thought up and tech's have to deal with their issues at the dealerships every day. My Master Tech. Instructor said that he removed an air bag that had the imprint of the woman drivers face on it ( even the color of her lipstick ), yes she had a broken nose. The seat belts would have been good enough. Notice that you now can't put an infant in the front seat, too many deaths with that. We have all learned how to drive with ABS and air bags and yes they sometimes save lives, but sometimes not.
  • For small money you can buy a device that has a small battery in it. Just plug it
    into what was called a cigarette lighter and that will supply the computer with the small voltage to keep the memory alive. As todays computers in our cars can total over 100 don't take all day to change the battery. There is voltage lost on top of a dirty battery that can be measured with a multimeter, just ground one side of the meter and drag the other meter wire over the top of the battery, there is an OEM spec for that. Turning on the head lights with the car off can get rid of that, but spray some battery cleaner on a rag and wipe
    it down get rid of the grounding effect of the dirty battery top ( don't forget to remove and clean the connections ). Check the wiring for an unwanted ground
    and if you spry down a battery with cleaner, NEVER use high pressure air to blow it off as the acid will do all kinds of damage to your car or truck. There is a whole lot more but that is enough for now. Try your multimeter to test the voltage from the clamp to the top of the battery terminal on each side, ( don't disconnect thing )
    see what you get. There is an OEM spec for that to.
  • mailformailfor Posts: 1
    Hi, my 2010 Toyota Venza has just 11,000 km on it. I've recently started feeling the transmission slip on the change from 1st into 2nd. Since I drive pretty conservatively to maximize fuel effeciency it cannot be attributed to driver abuse etc. i am really worried about this. I've driven older cars with transmission issues which is probably why i noticed it immediately a day or two ago and have since confirmed it several times again. This is a brand new vehicle, i'm really worried and dissappointed as its not what I expect from Toyota. I love my Venza. what should i do? Obviously i'm taking it to the dealer asap, however, I am skeptical about that entire excersize after reading some other owners experiences with dealers over various issues. Can anyone confirm similar issues and/or suggest what my next steps should be?
  • gowron67gowron67 Posts: 4
    edited April 2011
    I have a 2009 V6 AWD Venza and just had to have the transmission replaced at just 16,000 km. The engine check light and AWD lights came on and it seemed to slip out of 3rd and 5th periodically.
    My dealer told me that when they called Toyota they were told that this was a known problem caused by some inferior parts used in the transaxle (from an ouside supplier) and it would need to be replaced. No issues getting this done but makes you wonder that if was a `known issue`, how many other people have had this problem.
  • I have a 09 Venza Glass top. V6 at about 20.000 miles a noise from the tranny started, it sounds like a nasal wine in reverse and first gear. It got louder so I took it to Toyota of Orange, in CA, they said nothing was wrong, I took it back a second time, same story, third time back I insisted they look at it while I was there, they kept it for two days, called me said it was done. The service writer told me they flashed the computer and the sound has gone.
    With in a day it was back, I am going to try one more time, then I will look into having Toyota buy it back.
    I rented one in Sedona, and in Vegas, both V6 auto, no noise, the guy up the street from me has one he has no noise.
    I am asking for advice please. :cry:
    The type of coupling used in the Venza was totally new to Toyota with the introduction of the Venza. Ford had been using, Escape, Mariner, this technique, but not without an inordinate level of PTO and transaxle failures due to overuse, overuse by Ford design, of the F/awd technique on perfectly dry, HIGHLY tractive, surfaces.
    I have no doubt that a firmware revision, lessening the level of coupling to the front, will soon be forthcoming for your Venza. Were I to ever own a F/awd with a coupling of this type I would use a switch to open the rear drive control circuit except in known times of need.
    Porsche now uses the same coupling technique in the 911/997 & Cayenne, R/awd in that case though.
    edited August 2011
    If it's F/awd then disconnect the rear drive circuit, if the noise goes away...
  • Does the 2011 Venza 6 cyl have a transmission dipstick and tranny drain plug? I was told that the 2011 camry 4 cy has no dipstick and the salesmen said there was no drain plug.
    thanks, rr70
  • Hi I'm new and my English isn't good but anyway.I have Venza 2009 3.5cc AWD 29 000miles, last few mounths I have a problem whit my car,when I drive I feel tne car loose power like misfire or vacum problem on trafik light RPM play (900 to 200) after thath eng. light AWD and traction control light are ON.I was in dealership and they told me it's OK we can fixed ,after week I had the same problem then they change the maf or mas sensor I don't know and they sad now the car is perfect yes but no the same problem after 2 weeks.Then the car was in the dealership 13 days becose they call in California to ask help to fixet the problem once forever,after 13 days they call me and they sad you had bad conections but now it's ok "yes but no" next day the same problem and now I call in California and I sad I want new car end now I wait the paper . If someone know somethink let posted what cud be the problem.WOW I foget to tell you somethimes I feel the car cant shift very very hard.
  • This sounds an awful alot like what i experienced when my transmission failed. I am not much of mechanic but they said there was something in my transaxle that broke and they had to replace the whole thing but diagnosed it quickly.
    I was also told that when my dealer called Toyota that this was a known problem and they fixed it on warranty and I have had no problems since.
  • Probably you talking about my problem whit hard shift sometimes or mornings when is cold,thath was good inf. To know Thank you.If you or somebody else know more about my engine problem I lill so happy to know more.
  • Actually all of the things you said (traction light, engine light, etc) the feeling like it was slipping out of some gears, etc are exactly the symptoms that I experienced when my transmission on my venza failed
  • sotirovsotirov Posts: 3
    edited September 2011
    Ok I'm agree but when they check eng light the code are P0172 P0175 and two more but I don't remember
  • Same thing. Immediately after hitting about 5 mph everytime after a key start, POP.. it is the ABS brakes. It is the next generation ABS brakes doing a self test!
  • Hello!
    I want to ask you about a problem I had with my '09 Venza 2.7 4 cyl, 63000 miles.
    When I started it after a 12h parking(so the engine is cold) and put it in Drive car wasn't moving properly(I had 2000-2500 RPM but it was hardly moving, sorry for repetition). But after awaiting for 2-3 min with engine running everything becomes OK and then I don't have any problems with driving until next long-time parking.
    I'm not an expert but it seems like not enough pressure in automatic gearbox. I can't check the transmission fluid level because it has no dipstick.
  • I have a 2010 Venza 4 cylinder. It's been a great car except in recent months crazy things are happening.
    Transmission Shifting into Reverse: Randomly when I get into the car, start the car and try to shift into reverse, the transmission will not allow it to shift at all. Have to vigorous move the steering wheel back and forth, restart the ignition and then it seems to help get it into reverse. Has happend a dozen times in last 4 months. This is a random occurence.
    Electrical Warning Lights: Randomly the Brake, the ABS and the Slip Indicator warning lights light up. Does it randomly during day or night, dry or wet, flat or incline.
    Blue Tooth: My iPhone used to sync automatically when I entered car with the phone. Now I have to enter my passcode every time.
    Transmission Shifting from first to second: Big noticable clunk in transmission noise from first to second.
    I really like the Venza. Dealer checked the warning lights situation and said " everything checked out." They went on to say it's hard to diagnose if it's not happening when vehicle is in shop.
    What really concerns me is that in reading through all your blogs and messages here that this is happening to several people and that 1) dealers aren't able to help and 2) Toyota knows about this and is not helping.
    Please let me know what you know. Thanks.
2
