2008 Tucson V6 driving question
Hi all,
I just bought a 2008 Tucson v6 in slightly used condition. It had 6k miles on it. My major problem is that I can't get the darn thing up om the driveway- guess i should've gotten the 4WD! Any ideas...besides moving to a place where the driveway is not so steep?
Thanks in advance,
Brewbear
Thanks in advance,
Brewbear
SUVs and Smart Shopper
I realize I didn't say it, the front right tire slips. That is why i did try the lower gear (1) but no go. This is the first front wheel drive car i own and i figured it is my lack of know-how. The car owner manual is not very helpful in driving hints.
Brewbear
Has anyone else experienced this?
The house is in the hills so: I turn right into the driveway. I usually come down down-slope, turn right into the driveway which is slightly curved to the right and up-slope. The problem arises when the car is starting the ascent into the driveway from the street. So i guess, the best way to explain it is that I'm going from a descent into a fairly tight right turn followed by a sharp ascent on the driveway that bends to the right slightly.
Thanks for the help,
Brewbear
My drive sounds similar although there's no descent getting to the start of my drive. Your's is probably steeper than mine, especially at the start. My FWD minivan can't get up my hill when it snows and compacts. If the snow is fresh, usually I can make it. My AWD wagon never coughs. If I stopped 30' from my garage in dry weather, I may have to back down and attack it again in the van, but usually I can feather the gas enough to go up without digging in.
I drove FWD cars and minivans for years in snow country without much problem. My current minivan has high tread wear all season (i.e. highway) tires on it. I think with a better tire, it would make up my drive more times in the winter.
You may always have trouble in the winter if you get snow, but a better tire may let you get up your drive the rest of the year easier.
I never grade my drive either (except I'll even out the dips occasionally with a shovel). Those bumps really stall out my van in the snow too.
So I agree with Tidester - try lowering the tire pressure and if that helps, start budgeting for new tires.
If your drive is paved, then it really must be steep! You could always back up the hill.
I live in the Los Angeles area and snow is hardly an issue. Both of you guys mention the tire pressure so i'll go check. I made the assumption that since the car was bought from a dealer everything was up to specs...but then again, assumption is the mother of all f--ups, or so i've been told. I did think about backing up the driveway since that would be the lowest gear, so that's the next step. Oh, yeah, the drive is asphalt.
Brewbear
