One positive with this system is it is much cheaper and easier to replace then a traditional rack. To be honest, I don't mind trading some ease of steering for better gas mileage.
The bottom line is this, most compact cars are trying to become as fuel efficient as possible. With this system there is no power steering pump running off of a serpentine belt. It's just an electric motor bolted to the steering column that assists in your steering. This puts less drag on the engine allowing better gas mileage. If you want I quality steering system you're gonna have to pony up some more $$$$ because just about all of these compacts are switching to this EPS system. Oh, and of course these are cheaper for Toyota to install on a car than a traditional rack system.
I had to rent a Chevy Aveo, and after driving it, The Corolla steering was like driving a Lexus or MB, compared to Aveo's steering.....:)
I would start by getting the wheel alignment checked.
http://www.thecarconnection.com/news/1060392_nhtsa-clears-toyota-corolla-on-stee- ring-issues
While they did not find an issue to to make it a safety recall they did also say that a defect may still be present that they did not/were unable at this time todetect.
Also, if I remember correctly, 2 out of 10 test drivers were able to tell the difference before and after. So, 20% of the test group without knowing the issue were able to notice it.
If you are experiencing the issue I would recommend you have the EPS replaced under TSB-1040. I did and it made a huge difference.
We have the same problem over in the Sentra forums (wobbly steering, off-center steering feel). I also had some crap replaced in my Sentra's steering system (not the EPS) with no improvement.
Could you detail on TSB-1040? Is it related to Toyota only or is it some NHTSA document applicable to Nissan too?
If I was you I would not invest time into convincing terceltom about the EPS problem. Nothing will convince him that we have a problem: just read his posts allover the forums.
Here is a link to the TSB-
http://www.toyotapart.com/Steering_Off_Center_Feel_TSB014010.pdf
Sorry to hear about the Sentra but I can't think of any way, shape or form a Toyota TSB would impact Nissan. However, it is highly possible that both makers use the same 3rd party components so....that would be worth looking into. But again, TSB-1040 is toyota specific.
I suggest you and others start filing complaints w/ the NHTSA and ODI about the sentra and hope they look into it. I would encourage others on the forum board to file as well. That was how NHTSA got wind of the corolla and started their investigation. Bottom line is: If you and others do not get active in filing w/ NHTSA and their ODI and engage them nothing is really ever going to happen.
I will say this though - It was mentioned to me that another 'fix' was to pull the fuse for the EPS in the corolla. You'd lose the assist, but I was told that this also rectified the EPS wiggle. I never tried it, but it makes sense to me. I had toyota apply the TSB fix to my vehicle.
However, if anyone does pull the proper fuse they assume all responsibility and liability as I am not recommending this, but just passing along what I heard. But, perhaps a sentra owner would be willing to take the risk and see if that corrects the problem on the sentra. Hope that helps and good luck.
I rented a 2010 Corolla S a couple months ago and it did not have the problem.
I have replaced all four tires and had the front-end aligned and it made no difference. I replaced the tires because one of them was ruined due to running over a piece of metal. I didn't like the stock Bridgestone Turanza EL400 II tires at all, so I didn't want to buy one replacement for $187. Instead I bought four Michelin Primacy MXV tires. It handles a little better with the Michelins, but still wanders I have an appointment at the dealer on Saturday due to the problem and the 10k maintenance. I'd sell the car if I could do that without losing too much money.
I also own a 2005 Mazda RX-8 which also has EPS and it has no problems at any speed.
You may want to grab the TSB and see what the dealer can do. May have to press the dealer to get them to confirm it is the same EPS set-up on the '11 as previous models. But, it is. Otherwise you did the right thing by reporting it.
link-
here's the link again-
But, you may want to review the TSB. It contains a checklist of what the dealer is supposed to do to correct the problem.
If you have an '11 model then I'd report it to the NHTSA so they can at least keep track of it. Remember - they did not find a safety issue for the '09 and '10's so a recall isn't going to happen. However, toyota did re-tune the EPS module and is replacing the EPS under the above TSB for those that are having issues.
I had to take it from one dealer that didn't think it was an issue to another dealer that said no problem we will take the warranty/TSB work and did it without having to hassle with it. So, if one dealer is giving you a headache take it to another one IMO. They did take my car for a few days to go over it and then called and said - yes, it is doing it (after going thru the TSB checklist) and we will order the module for you. They are not going to have it in stock. Had my car back in 3 days and made a world of difference IMO.
I have seen nothing that says toyota used a 'new' EPS for the '11. I believe it is the same as the '09 and '10. In fact, when I called the NHTSA and talked to an engineer about it he said (at the time and this was months ago) that toyota would be using the same EPS module in the '11 models so.......
If you go onto the NHTSA safecar.gov site you can search for the documents and see the back and forth between the NHTSA and toyota. It is all public record. From there you can find names and numbers of the NHTSA people. It's not hard just gotta know where to look. Hope it helps.
So if you are wondering if the TSB works. Yes it does. Just take it to a good dealer.
A couple of weeks ago I got the lead tech at Toyota, who adjusted the alignment to have a little more toe (within tolerances). The car was set at ABSOLUTE ALIGNMENT??? This adjustment made driving the vehicle much more bearable, but NOT PERFECT. He also made my complaint known to Toyota to see if any adjustment were available.
I hope this information can help people feel a somewhat safer while driving
Is there anything I can do to not have the power steering firm and resistant at high speeds? Is there an adjustment that can be made? Would I of had this issue if I bought a 2012 Camry? It creates great fatigue when driving on the highway.
I can barely keep the car centered in a lane at highway speeds.
Tires at specified 32F/32R
Will contact Toyota regarding TSB 014010
