Erratic Idle for CR-V
My wifes 2000 CRV has an idle problem. It's erratic going high and low at idle. A code 505 comes up. This code is for the IAC Valve. I replaced it and it did not change. This all started after the A/C Compressor replaced and the valves were adjusted.
The CRV has 212,000 miles on it. The head was reconditioned one year ago at 185,000 miles when the catalytic converter plugged and burned all the exhaust valves. It ran great until the A/C Compressor problem developed.
Has anyone ever had this idle problem?
SUVs and Smart Shopper
This is a tough one. I hate to return to the Honda dealer and get hosed again.
Thanks again tidester.
Been trying to get enough time to get into it. When I find out I'll let you know what I find.
Before I removed the head I checked the valve clearance and all were at factory specs.
Replaced the timing belt, tension pulley, and water pump along with the head gasket and valve cover gasket. The CR-V has 230,000 miles now and runs like a swiss clock. I checked the valve clearance at 200,000 miles and still at factory specs. I'll be checking them again very soon and do not expect any change.
I recommend you do a compression test to rule out any valve problems. My problem was the idle was erratic, going up and down about 100 rpm's. I never expected burned valves with this erratic idle condition. You can never tell. My experience with burned valves in the past the engine would miss fire or skip.
Hope this helps. If you need any more info. don't hesitate to e-mail me.
Bob Deschenes
I doubt I have burned valves as it only has 93k km (57000) miles on it. But that said I have also not done a valve adjustment and have been meaning to check into it. I plan to this summer, to at least check the tolerances. It's too cold here now to check them anyway as it should be about 70¼ or so right?
