Loud Screeching Noise on a Chevy Blazer
I have a 98' Blazer and just had the transmission replaced recently. Not really sure if that has anything to do with it but the other day I went to take the truck for a drive when it started screeching loudly while I was driving down the road. All the electrical started dimming and it seemed like it was starting to stall. I was able to get it back home and figure out when it would start screeching. It seems to do it when I pull the shifter down between D and 3. I barely pull it out of D and down into 3 and it squeels like crazy. I've had conflicting ideas of what it could be.
Any ideas?
Any ideas?
SUVs and Smart Shopper
Another interesting note is that I took the truck for a drive and held the shifter upwards and it did not make any noise at all. Could it be something in the steering column or could it be the transmission causing the problem?
It is leaking some kind of fluid from directly underneath the engine and it's also leaking fluid from the pumpkin ball in the rear. Might this also have something to do with it?
The leaking fluids would have me concerned. Can you describe the fluid? Odor, viscosity, color? That might help someone diagnose your problem.
The fluids are a darker color. Like a dark brown. I checked both fluids that are leaking and they smell like the same fluid. Maybe these pictures could be of some assistance:
The differential is interesting. That is not the typical leak pattern for a bad gasket. I see a lot of rust on the cover, check carefully that there isn't a hole.
Re the squeal when put in gear; has this been in water? You might need to drop the tranny pan and check for water, dirty filter, etc.
The 1995-up S10 Blazer aluminum pan requires a M12 x 1.75 drain plug and that plug with an oversize thread can be purchased on-line at CG Enterprizes ( www.cgenterprises.com ) which is their #1027 drain plug and #2201 gasket. A better option would be to install CG Enterprises #1048 M12 x 1.75 OS double (piggy-back) drain plug and a #2201 gasket. You can install the OS double drain plug with Loctite #262 permanent thread locker and never have to remove the M12 x 1.75 drain plug again. In order to drain the oil, you remove the smaller "piggy-back" drain plug that is threaded into the main M12 x 1.75 drain plug that you have permanently locked in the pan with the Loctite thread locker.
The very last option would be to replace the oil pan with a new one. Unfortunately, you must remove the engine to do that. The high cost of replacing a oil pan is why the OS drain plugs and the piggy-back drain plugs were invented and introduced.
"When the price of eggs get high enough, roosters will start laying"
I also played around with the shifter some more and it only makes the loud noise when it's put in to or taken out of drive. It doesn't do it with park, reverse, neutral, 3, 2 or 1.
I also noticed that the check engine light was on. I ran the codes and it came back with a bad O2 sensor. I also think that the catalytic converter is bad.
Could the cat be the cause of the loud noise?
Also, is replacing the cover for the differential difficult or is it just taking the bolts off and replacing the cover?
Regarding the noise, any chance a heat shield is coming in contact with the linkage when in the drive position? May need to put this one on a lift to isolate the location.
The typical noise from a bad cat is a marbles in coffee can sound, or a loud sucking/whooshing sound if plugged.
A vacuum leak can trigger a false O2 sensor code. Several mechie's have told me the O2 sensor is the most common mistakenly identified failure around.
