2006 Kia Optima lost both low beams at the same time
talltom1talltom1 Member Posts: 3
edited July 2014 in Kia
No low beams at all. Checked all fuses and grounds that I can find. I guess both could have burned out at the same time but doubtful.
Any ideas where to start
  • mickeyrommickeyrom Member Posts: 936
    I can't help,but I am curious...is it the old 2006 or the newer 2006.5?
  • talltom1talltom1 Member Posts: 3
    Its the old style 06, got it cheap since they had the new ones on the lot at the same time.
    Tom
    If it's within the mileage limit,it should be covered by the warranty..have you checked into that?
    drive train is 100,000 but I was thinking the electical parts ended way before that.
    I need to check the waranty manual.
    Thanks for the tip
    Tom
  • jimrichjimrich Member Posts: 4
    edited July 2010
    Sun visor? What can go wrong with a sun visor.Mine is a 2006.5 and the visors are like new.
