Honda CR-V Cruise Control
Cruise shuts off when set, first will change idle speed then start slowing down. if i hold down the gas peddle the cruise will eventually shut off. It will than work for awhile when the cruise is shut off and turned back on.
Not sure how it even hold the idle speed since cruise will not operate under 30 mph, as per OWNER's MANUAL.
doyle
You are driving along on the highway at 65 mph.
You press the cruise control switch to activate it.
Then you press "SET" button to set cruise control.
Transmission shifts down, engine revs up, and the vehicle slows down?
Do you have to go through a turn or something right before cruise shuts off? If so, the reel inside the steering wheel that routes the wires may have a short and is basically sending a "cancel" signal to the cruise unit.
Just a thought.
Try to note what happens right before cruise disconnects.
Also check the two switches at the base of brake pedal. One should be for the brake light, and the second should be for the cruise cancel. Although, they may have been combined.
Chasing electric ghosts is not fun, but once you can reliably repeat the symptoms, you know you found the gremlin. Just follow the wires, and cables. Get the shop manual either form Helm corp or on ebay.
Doyle6
Car works well overall. Cruise control will hold for 30 to 40 minutes, less on hills. Then sputters, light on dash goes out, and cruise shuts off and speed drops. Car still running. Main cruise switch still on, but must be turned off and then on again to reactivate cruise control. The cruise system will now only hold for 10 or less minutes.
The other, less desirable possibility is that the module that actuates the throttle is going bad. I think it's a stepper motor. IT might have an issue and is overheating after a while.
anybody knows how can i disconnect the speed buzzer that my car has when the speed is upper 120Km/h (around 65 miles/h)? My car has not cruise controls, them really i do not know how to do it.
Many thanks for your help,
I can only assume thsi is an aftermarket device that a good shop should be able to remove or disable. It's probably plugged into the ECU wiring harness wince it needs the speed information.
Honestly, I've never heard of such a device.
Thanks a lot for your help,
Personally I wouldn't drive a vehcile without airbags. The risk or neck and head injuries from impat to the windshield and/or stering column are very real.
Also, I'd besuprised if you could get insurnace on a vehcile without them. You might have any medical claims rejected by both your car insurance and you medical insurance. the insurance for the other diriver might also be able to reject certain claims.
Just all in all a bad idea. Get the car fixed! $10,000 in the end isn't a bad price for a 2006 in good condition otherwise. You might be able to get a regular title after the repairs are completed.
