Mazda 626 Bad Idle
I have a 2000 626 4 cyl 4 door car. When it is cool outside it runs great. When it gets over 90 deg. outside it runs bad. The check engine light came on and the code was number 2 cyl misfire. Only dose it at idle. The shop said Plugs. I changed the plugs, wires and coil pack. No luck. Next it the fuel injectors. The dealer wants $1200.00 for a new set and that is not installed. Any ideals before I wast that much cash.
I have been following this subject very closely because i have the same problem.
I have changed the following - Air flow meter, plugs , ignition wires , distributer cap and rotor ( this was very old and carbonised) air filter, oil change( including oil filter) and just this mornng I cleaned the throttle - the list goes on. The engine is very smooth now after all renewed componenets except for the fact that it stops in a few minutes of idling. I have almost given up now ... i will take this for a long drive later today and if that does not help then not sure what next ... but will keep you posted ...
Thx
