2001 Jeep Grand Cherokee has trouble starting.
My Grand Cherokee has trouble starting up from cold. The first time I try to turn the engine over, it just won't start. Then when I try the second time, it ALWAYS turns over. This has been going on for 3 months now. I never have any engine problems, it just doesn't want to start on the first try. Any suggestions will be appreciated.
SUVs and Smart Shopper
if i turn the engine off it starts right up
i was wandering if anyone with this engine type v-8 has experienced this.
its been acting like this for about a week. could it be the gas filter clogged?
thanks for any replys on this.
I have also read a lot of suggestions for replacing the crank position sensor for the same problem as well. Has anyone tried that?
is it simple to replace this part and do i need to take belt off before removing bolt
In the beginning I could let it sit (after shutting down) for about 30min and it would still crank right up. However over time, I couldn't shut it down and run in the store for 5 min without it having trouble cranking. I took it to a mechanic and as I've read in all the forums, he suggested it was the fuel pump. $550 later it was not the pump. He cleaned the injectors cause he said they were clogged and that didn't solve the issue. I finally just took the jeep since he didn't have a clue of what the issue was. I replaced the fuel filter, crank shaft position sensor, temp sensor, plugs, and nothing worked. Finally I read an article that mentioned leaky injectors. I did the poor man's test but didn't have a leak. I did however think it was an injector issue, maybe clogged or failed. So I purchased on injector from O'Reilly's for about $40, took the injectors out and noticed all were shiny except #6, it was a dull color. I replaced that this weekend and the jeep cranks every single time just like new.
I have seen so many articles with people having the same issue but the thread would die off with no solution noted. I hope this fix will be able to help you guys and hopefully save you some money and offer a solution that doesn't take 1.5 yrs to come by.
