Nissan Pathfinder A/C Drain Problems
I have a 2007 Nissan Pathfinder and recently noticed that the floor on the passenger side is wet. I did some poking around and discovered that the condensation from the AC is somehow draining into the cab. I cannot find the drain to see if it is clogged or disconnected. Where is the location of the drain for the AC in my truck? When the AC is running condensation is falling off of the frame almost directly under the passenger side floor. I am not sure if this is where the AC is supposed to drain. My warranty is up and I need some guidance to try to remedy this issue myself. Any Help is appreciated.
Paul
ChrisM
