Hope Lucy continues to recover well from the surgery.
Tom
Have you hugged your Jeep today?
http://www.geocities.com/MotorCity/Lane/4886/jeepeng.html
Regular oil as recommended in the handbook is fine. Just remember to change it regularly.
It's an old, heavy, slow turning, long stroke, straight six with a lot of torque at low revs, making it the virtual antithesis of a modern, lightweight, high revving, short stroke, V6 which makes most of its power higher up the range.
Another indication is the is the way it can take substantial power increases without problems. Supercharging is not uncommon and neither are stroker conversions.
All the above, combined with its proven ability to run to high mileages with only regular service, indicate it's running nowhere the limits of its capabilities.
I guess it's overkill, but I DO like the Mobil 1 oil, and that's what Thelma Jane gets. I like it for its cold flow characteristics, and I DON'T use it for extended drain intervals. I still try to get the oil changed at 3000 miles, but I NEVER let it go past 4000 miles, even with the Mobil 1 oil.
I guess I have told this story before, but you guys know how old people are... they tell the same stories over and over. Anyway, I had a 94 Z28 Camaro that had the LT 1 5.7 liter engine. It made lifter noise fairly bad on cold starts. As soon as I switched to Mobil 1, the cold start noise was virtually gone, and the little noise it DID make stopped much sooner than before. It also increased my gas mileage by 5%, and that was not just on a tank or two of gas. I was in the habit of checking gas mileage EVERY time I filled up, so I had a long history of gas mileage for a basis of comparison. I consistently got 5% better gas mileage with the Mobil 1 oil in the crankcase.
Now a 5% gain in gas mileage is NOT going to begin to save you enough money to pay the extra cost of the synthetic oil, but if the gas mileage has gone up, it must mean that friction has gone down, and that's a GOOD thing.
I have a GM dealer near my workplace that changes the oil and filter, does the lubrication, and tops off fluids for $5.95, when you bring your own oil and filter. Can't beat that, so I don't bother doing it myself. They allow me to stand right there beside the guy doing the work, so I can see that it is being done properly. I would never allow someone else to change my oil, if I couldn't personally supervise up close and personal. And, they have recently started letting whichever of their regular technicians that is available do the work, not just some kid that does only oil changes.
Tom
Those guys with the Dana 35s tried it, and I think they could have made it, but with the 35s, you have to be very careful about situations where you spin a tire and then it grabs, and then it spins again, and then it grabs again. That grabbing all of a sudden after spinning puts a heck of a stress on the axle shafts, and these guys were afraid to go on, so they quit trying. One of the guys had 33" tires and the other guy had 35" tires. Neither had lockers.
That's kinda pushing things when ya run 35" tires on a dana 35 rear end, and a locker would make breakage even more likely. But, the locker is what helped Thelma Jane go on up that steep climb.
This is why I recommend so strongly that you get a dana 44!
Tom
Another thing to consider is maintenance/warranty work. Although your local dealer will do the work for you, even if you didn't purchase from them, they may not be as quick to schedule you into the shop or as likely to give you a loaner vehicle if you didn't purchase from them.....
I remember when the new generation came out in 1996 (as a 1997 model). The reviews were all very positive. They all said how much more refined the ride was than in previous generations, noise had been reduced, and how the soft top was dramatically better than before.
Now I read Edmunds' review on the 2004 Wrangler, essentially the same vehicle that rolled out in 1996, and they complain quite a bit about the noise and how the soft top flaps around a lot at speed. I wonder if the expectations have changed over the last seven years or so.
Can some of you guys give me a better idea of what kind of noise we're talking about here? When you drive a soft top Wrangler, top deployed, can you hold a conversation? Can you hear the radio at normal volumes?
Does the hard top make a significant difference? Lastly, what is faster - deploying and removing the soft top or deploying and removing the hard top?
I would say the time to deploy the tops is about the same. The soft top is a little more involved, but the hard top requires a friend to help you or to have a hoist in your garage. I have the soft top only so I can just zip out the windows and put them in the back lower the top and have everything with me in case bad weather moves in over the course of the day. The soft top can be taken down in less than 5 minutes and put back up just a minute or 2 longer.
I have even heard some say that there is very little difference in noise level between the new soft top and the hard top. Probably the folks that say the new soft top is amost as quiet as the hard top have the full metal doors, so the plastic windows flopping around are not a problem for them. I think if I were getting the soft top, I would want the full metal doors.
Joe, you always have to take "reviews" with a grain of salt. For Pete's sake, they rate a Jeep by the same criteria that they use for cars. That's stupid! They say a Jeep is noisy and rides rough... well DUH! Compared to a car, that is true. People who buy Jeeps are well aware that a Jeep will be noisier and have a rougher ride than a car.
You asked about the ease of removal of the soft top vs the hard top. I can only talk about the hard top, since that's all I have.
To remove the hard top, you have to remove six torx bolts, unlatch two latches (above the windshield), disconnect the electrical connector for the rear wiper, and disconnect the line for the rear washer. All of that can be done in ten or fifteen minutes. Then, you need a second person to help you lift that hardtop off. It is very awkward to handle and very heavy (about 140 lbs). It is not something you would want to do every couple days. Once it's off, you would want to leave it off a while, and vice versa.
Joe, as long as a person understands the sacrifices that have to be made in going from a car or SUV or whatever to a Jeep, and as long as he is willing to make those sacrifices for the pure FUN of a Jeep, then that person will not be disappointed.
If you know my history from reading posts in here, you know that I was trading all the time, never satisfied for long with whatever I bought. Well, that is over with! I have had my Jeep almost three years, and I wouldn't even THINK of trading her! Three years may not sound like very long, but it's the longest I have had a vehicle since I bought a new 1974 Ford pickup and kept it ten years.
Do you know anyone that has a fairly new Jeep? Or can ya do some test driving? You need to see for yourself what a Jeep is all about, and then decide if it's really what you want.
Tom
Where this is leading is that I was thinkin' you would probably want the soft top out there. During the heat of the day, you would want the top up and the A/C on, but when the sun gets low, it would be nice to drop the top, right?
Now you SURE don't want to have to remove the hard top and then put it back on every day, so the soft top would be your best bet. Are there times when you think you would want the hard top? If not, save your money and get the soft top only.
However, if you think you would have use for the hard top, the best time to buy one is with the Jeep to begin with. A new factory quality hard top can never be bought cheaper than with the Jeep to start with. You might find some used ones, but even they will cost about as much as the dual top option you could have gotten from the factory.
Tom
Recently we test drove an 03 soft top with half doors and I was really surprised. It didn't flap at all and it didn't seem much louder at all. Noise would not be a reason for choosing a hard top over a soft top.
I would, however, not want the half doors unless I got sliders to replace the windows. The zippered windows would drive me up a wall - imagine getting a shower if you are going through a drive-through in the rain, or using a card-key for a parking lot or other similar situations.
I do think that the hard top provides better insulation when it comes to heating and cooling. I do know that the hard top doesn't have a problem with 30 inches of snow in one night (something we had 2 years ago) so if you are up in the mountains, that's something to think about. And it seemed like the hard top I test drove the same day as the soft top cooled down faster than the soft top (Bakersfield in the summer is similar to some Arizona locations).
If I had a garage I'd want the dual top options. Since I don't have one, I'll always opt for the hard top, but that's just me and my situation. Others will prefer the soft top.
Might have to get one of those videos... sounds like a good deal.
Tom
Hey, have you found any possibilities for a Jeep purchase lately? I'm still keepin' a lookout for one for ya.
We had a good clean up day at Turkey Bay Saturday. What a gorgeous day it was! Man, I love the fall weather. Lookin' forward to the leaves gettin' their fall colors.
Tom
I just looked at a '94 this morning on the way into the office. Pretty much what I am looking for - no options, no frills, but in decent shape. It has 31 x 10.50's on it now, but doesn't seem to have any sort of lift. There is no body damage or rust at all, except for the bottom of the tailgate. I've noticed this on several Jeeps. The drain holes appear to be plugged with the bottom rusted out. Is this common?
I can almost guarantee you that you are in range for a 97 or 98 TJ SE, if you will just keep searching. Heck, you might even find a Sport with high mileage on it for that price. For your purposes, strictly trail use, I would get the newest Jeep I could find in my price range, rather than worry about getting a six cylinder. No advantage to the six over the four on the trails, but BIG advantage for the TJ over the YJ on the trails (stock to stock, anyway).
Have not noticed the rusting of the tail gate that you asked about, Jim. Guess you are talking about the YJs?
Tom
Man what a difference between the stock SE wheels! I put the BFG 30x9.5's on and am happy with it. The A/T KO's are fairly quiet on the road and it handles SO much nicer. Now to find some non-road stuff to play on. heheh
I put on my new Bestop sailcloth replace-a-top too. The Jeep looks like a totally different truck.
As for the comparison between tops, the old top had one layer (you could see sunshine through it). The new top has the multi-layer setup that Tom mentioned. It IS much quieter. You can carry on a conversation quite easily now, whereas the old top pretty much required earplugs. I also have the soft halfdoors. Even they are quieter than the originals. I would have preferred sliders, like mtngal mentioned, but I had to wait on that for the time being. Maybe later...
I am considering finding a hard top and the full steel doors, but I know that'll be quite pricey. I'm assuming I won't find the right color, so they'd have to be painted.
I have pictures of the 'new' Jeep at Webshots:
http://community.webshots.com/user/skimblz_
-Paul
Big difference from when you bought it.
Just shows how easy it is to improve a Jeep.
Now, it appears, however, that you have forgotten something. THOSE BUMPER CORNERS! They gotta go, Paul.
Seriously, they come off pretty easily without doing them any damage, so you can always put em back on, but you really oughta see what the Jeep looks like without them. Heck, if ya tear one of em up, I'll send you one of mine. You can have ALL of mine, if ya need em.
Now, a question... is that YOUR Jeep or your daughter's???
Sounds like what happened with Ross Allen. He started off being my daughter's doggy, but old Grandpa took over.
Tom
It is technically my daughter's car, since I sold my Honda Civic Si (which I gave to her) to pay for the TJ. But it is kinda my project car.
I use the my/her possessive pronouns interchangeably. I get to drive it when I want, as long as I ask her first and as long as she doesn't need it for school or work. She has priority on it.
I was looking at those bumper covers this weekend as was thinking the same thing. Do they just pop out? I'd like to pull them out, but my wife may not want me to. I may just do it and not tell anybody. hehehe
My wife did say that if we moved to Colorado, I could get a Jeep... let's get packed!
If I was buying one for ME, I'd probably go with a Sport or a Rubi. But thinking about it, I could probably get the X, but upgrading to what I would want in it would come up to Sport range rather easily. So I would definitely get the dual tops (hard for winter months, soft rest of the time).
-Paul
I'm starting to wonder myself. :P
Just thought I would point out something that probably is not in itself important enough to base your decision on, but could be a factor.
You know there are miles and miles of 300 and 400 series roads all over LBL. These roads are not maintained or only minimally maintained, and they require 4WD in some places. These roads are fun to explore sometimes, but your vehicle has to be licensed in order to legally drive on these roads. Big fine if they catch you on them with an unlicensed rig.
Since you live only 40 miles form Turkey Bay, it would seem to me to be better to just drive your Jeep over there rather than trailer it. You pull a camping trailer already, right? So, if you wanted to camp AND wheel, you would need to drive the Jeep over there, right? Maybe Momma could drive the Jeep while you drive the truck with the camper in tow???
Sorry, I'm sticking my nose into your business, ain't I?? Oh well, I just get carried away sometimes, especially when someone is getting a Jeep.
Tom
I ain't no biggie to take em off and see if you like the looks better without them. You can always put em back on.
Can't blame ya for taking such an active role in that Jeep, even if it is officially your daughter's.
Tom
Have you hugged your daughter's Jeep today?
My wife absolutely refuses to learn to drive a stick, so having her drive it to the campground is out of the question. My truck is perfectly capable of handling the extra stresses and weight of pulling the Jeep behind the camper, however, I'm not sure if the camper is heavy enough to handle the Jeep. If a Jeep weighs 3,500 lbs, then I know the camper will at least double that weight. Of course, then I'll be getting mighty close to that 20,000 lbs GCWR!
Does anyone here know the rule for towing tandem with regards to how much more the lead trailer must weigh?
The rust has all been on YJ's. I haven't been able to physically inspect any TJ's yet.
Man, I don't think I have ever seen a truck pulling a camping trailer AND another vehicle! That would be a traffic jam all by itself!
I don't doubt that your truck would be capable of the load, but, Good Lord, how would that "train" handle on the road?
If you went through a drive through at Mc Donalds, someone in the Jeep would just be placing their order while you are picking up your food.
Tom
Didn't see any in the pics (unless I'm being blind), but if you're planning on taking it wheeling, you should get tow-hooks on there...
Andrew
Tom
But, you are exactly right about the tow hooks. I didn't notice that Paul's Jeep didn't have them. Paul, those things are a MUST, if you are going to go offroad. The bumpers just are not strong enough to be used to pull a Jeep out of a "stuck," especially since a Jeep often has to be jerked out of a bad stuck, instead of just being pulled out with a steady pull.
Tom
Got that line from Marlon (bored7287). Thought it was pretty cool. Thanks, Marlon.
I used my personal day, so at least I didn't lie about being sick. (Save that one for next time )
Tom
This is what happens when I'm coding and writing messages at the same time... I'd hate to think about what I may have accidentally included in the code!! ;-)
Andrew
-twylie
I am concerned about it on two fronts: One you've already mentioned. I've read lots of stories about this very topic - truck pulling a camper pulling a Jeep. Some use a flatbed trailer while others don't. It seems most setups without the flatbed work just fine, but I've read a few where the Jeep really did some serious fishtailing behind the camper. The other concern is the campers frame rails being heavy enough to literally pull the Jeep. It has 8 inch full length rails under it. Just by WAG'ing it, the rails look strong enough. But I'd rather not WAG it. I need to talk to someone that would know. If I don't license it, then add another 1,000 lbs to the equation for the flatbed trailer.
I am definitely taking my time with this decision. Last night Janna told me she wanted me to get a new bike instead, but didn't care if I got a Jeep. I think she got to thinking about her Saturdays being free if the boys and I are out in the Jeep.
1. Tow hooks or D-rings front and back.
If you wheel, you are gonna get stuck. If you never get stuck, you just ain't being adventurous enough. We always think of mud when we think about geting stuck, and that is most often the case, but you might get high centered on something and need a tug. I'm sure there are other situations too. I guess one thing could be that you break down on the trail and need to be towed out. The Jeep bumpers are nowhere near strong enough to use to tow the Jeep. You need tow hooks that are bolted THROUGH the bumper (not TO the bumper) and into the frame. Since you never know which direction the pull will need to come from, front or back, you need tow points on both ends. Be sure and get tow hooks rated for at least three times the vehicle weight, since there might be times when you need to be jerked out of a hole, and you need something heavy enough to take the shock load. Be sure the bolts that are used to secure the hooks are grade 8. The factory hooks are fine, but be careful about after market hooks... make sure they are heavy enough and the bolts are strong enough. All of this applies to the D-rings also, if that's the way you decide to go.
2. Tow strap
Yeah, you can HOPE that someone else in the group has one, but proper ediquette is to have your own, and if you get stuck, to use your own. Don't expect someone else to get their tow strap all nasty in the mud when YOU are the one that is stuck. Guess who gets to wade in the mud to hook up the strap???
DO NOT get the tow straps that have the metal hooks on the ends. They are not even allowed by most Jeep clubs. Those metal hooks can be deadly if the strap breaks or slips off during a pull. Get the straps that have loops on the ends.
Get either two or three inch straps with at least 20,000 lbs capacity. Here again, the "shock load" factor comes into play. As far as length, 20' to 25' ought to do the job. I have a 25' strap with 20K lbs capacity.. got mine from autobarn.com for $36.95 plus shipping.
These things are also called recovery straps.
CB Radio
Now for Pete's sake, let's be getting a CB radio for our wheelin', peeps! I have to admit that I did not have one the first couple times I wheeled, but I am ashamed of myself for that. The second time out, I hooked up with some super nice folks from the Central Illinois Jeep Club, and one of those guys was kind enough to get out of his Jeep and walk back to mine to relay messages. That was way above and beyond the call of duty, and it embarasses me that he had to do that for me.
All you need is the cheapest CB you can find, and I got mine at Walmart for about $40.00. Get a cheap antenna and some coax, and you are in business. I'm sure you can get everything you need for well under $100.
When I was talking about tow hooks and tow straps, I mentioned mud. Well, you guys know that I avoid mud whenever possible, but sometimes you just have to go through it on your way to some cool place you want to go.
Tom
I didn't make that joke, some genius did, and I just passed it along.
You really should have just gone into work, Tom. :-)
erickpl-Good job on your---err---your daughter's Jeep! It almost looks new, except for those clearly faded flares. I'm sure the others have tips on how to get the shine, and darknesss back, but I do know this...don't use Armor All! I don't even use the stuff on tires!
Thanks, Mac, you really made a good explanation about the 4.0L engine. I just now need to know whether a 2.5L or a 4.0L higher mileage engine will last 2 years, with daily driving (10+ miles), since all the Jeeps that I have the patience to save money for are high-mileage.
The Wrangler family is just so nice, the rest of the Jeepers seem to always hold some sort of anger against others. Thanks, everyone.
-Paul
Andrew
I went through a dealer and got the factory hooks when I knew I was going to start wheelin. I think I might have broken the rule and went one time without hooks, though. I believe it was just before my second excursion that I got the hooks and put them on. The rear hook bolts into the frame, so I don't know why anyone would think they are not adequate. (The factory only puts one hook on the back, and it goes on the drivers side).
There are cheaper ways to go and still get a good tow hook rather than going with the factory hooks, but I wanted them to look good and wanted them to fit without having to fool around with them.
Tom
I would be careful about how much heat and how long you expose a spot to that heat, but I have heard from several different sources that it works like a charm.
Just go easy at first and get a feel for how much heat it takes and how long the exposure needs to be.
I have heard about some various commercial liquid products that work for a while, but I don't think I have heard of any that last very long.
I have also heard that if you get the right type of paint that you can make em look good and the job will last a good while. Don't remember what type of paint it was right now.
Tom
Andrew
I'd try a few coats of 303 first and if that doesn't work, maybe test a spot with Back to Black. I think the B2B may be a silicone based product so use at your own risk
Krylon link:
http://www.krylon.com/product/gp_product_detail.asp?sgID=GP07
I like the factory flare look over the aftermarket flares. JMO.
-twylie
I picked up a 20ft 25k tow strap as a backup from Home Depot for $30.
-twylie
When I got my winch, I got an accessory kit with it, and in the kit is a "tree saver" strap. This will serve as my short strap. A tree saver strap is the same thing as a tow strap, but it is much shorter and is intended to go around a tree that you are using as an anchor point when using your winch.
Good Jeepers believe in "treading lightly," and they don't damage a tree by putting a wire rope around it when winching.
I don't know where you would get a short tow strap other than in a winch accessory kit. I'm sure they are available somewhere.
Tom
