2010 Chevy Equinox Problems
19192949697117
  • kcarissekcarisse Posts: 5
    Hey all, for a sense of completeness I just wanted to post what's happened to my Equinox. I had posted earlier about the stalling problems I had with my engine. It happened repeatedly and since its started I've replaced the timing chain, timing chain guide, cam shaft position solenoids, intake/exhaust actuators, and fuel pump. I was getting too scared to drive the car, especially over any long distances. As of yesterday, I finally caved and traded my Equinox in for a Mazda3 hatchback. It was a bit of a financial hit, and the M3 is smaller, but I trust it a lot more. I also have another Mazda3 which has treated me great, so I was more comfortable with the brand.
    I know the right thing to do would have been to continue the oil consumption monitoring and make GM fix this. But honestly, my husband and I are both so busy we just dont have time and energy for this nonsense. And we need a vehicle we can both rely on.
    No more GM vehicles for this girl ever again - lesson learned.
  • gmcustsvcgmcustsvc Posts: 4,251
    jampal75,
    Are you working with your dealership at all to get this checked into? Please let us know if there is anything we can check into further - we can be reached via email at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
    Sarah, GM Customer Service
  • rebcky27rebcky27 Posts: 3
    I purchased my 2010 Equinox one month ago from a used dealership with 102,000 miles on it. Within the last 2 weeks I have had by check engine light throw code P0014 "camshaft position timing" 3 times. I've noticed it running loud (similar to a diesel engine). When driving home from work it stalled on me 3 times in the same drive when coming to a stop, had to park, turn off the engine and restart to continue home. Husband checked the oil dip stick last week and noticed it was low so he put in 2 quarts. I myself placed another quart in 4 days later and then 2 days later removed the oil cap to find a chalky white all over the cap and dumped liquid out of the cover that covers the engine. Had it towed to a service shop over the weekend and they told me this morning there was less than 1 quart of oil that drained out!!!! I JUST purchased this vehicle and am getting no help from the dealership as it's over the "30 day/1,00 mile warranty" - I drove 200 miles to buy it from them and average about 700 miles A WEEK driving to and from work. I see no valid reason this vehicle should be losing this much oil. The service dept preformed a combustion check and no leaks were found. I will be monitoring my oil at least twice a day to see how fast it's burning.
    Not having any help from the dealership and probably not from GM either as it's past the 100k powertrain warranty I'm at a loss to what I can do. It seems from every one's postings that this is a serious engine problem resulting in new engines. Does anyone have any advise for me?
  • Hi,
    A couple of things you can do to mitigate the errors with these engines.
    1/ Change the oil every 3,000 miles and make sure you change the filter at same time.
    2/ Make sure you use the 5W30 synthetic oil that GM recommends.
    3/ The white substance in the oil cap is atypical of these engines, usually caused by the build up of contaminants in the PCV filter on the engine. These PCV valves are easily changed, check a factory or Chiltens manual for instructions.
    4/ Make sure the oil is not leaking out past a bad seal...does the car drop oil when parked overnight?
    5/ The errors generated by the engine management system are easily cleared by purchasing your self a code checker from Sears or an auto store...camshaft positioner errors are usually caused by too thick and oil or too dirty an oil condition... make sure your oil filter has been changed by the dealer...its hard to get to the filter and some repair shops shortcut this action...resluts in clogged sensors and errors as you have reported.
    If your engine has no physical oil leaks, but contiues to "use oil" you should be aware that GM indicates that these engines will consume oil at a rate of 1 quart for 3000 miles...excessive to me, but it is what it is.
    The only option if the engine is actually burning the oil is to rebuild the engie or purchase a replacement GM unit...there were a lot of defective build GM engines, especially in the 2010 build year...you can search these forums for some horror stories...why this hasnt hit the national headlines as a disgrace to GM is beyond me...
    Hope the above helps... :lemon:
  • carguy05carguy05 Posts: 30
    Dear
    Aussieinva, Sorry this will not be any help to you, but why would you buy a 2010 equinox with 102,000 miles or any american car with that mileage. I have the same car with 59,000 miles. and had oil burning problem early on, but now I use synthetic blend every 5000 miles and only have to add a quart every 2500-3000 miles. I will be getting tid of this car in 6 months. Good luck.
    rebcky27,
    Is the dealership you have been working with a GM dealership? Let us know if we can check into anything for you - we can be reached via email at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation).
  • elli2elli2 Posts: 15
    Gosh ... I hate to say this, but I'd fill it with oil and sell it as quickly as you can. Many of us have had the exact problems, but were within the warranty period (at 43,000 miles mine is in the shop getting a new engine as we speak). The only thing that will solve your problem is a new engine - which of course will cost a fortune. I'd dump it as quickly as I can. You might also consult with a lawyer, because the dealer who sold the car to you certainly knew of the problems and should have represented them to you, I would think! You clearly had problems that you can document within 30 days of the purchase - even if you didn't report it within 30 days. I'd try it. Pressure from an attorney might help the dealer to take the lemon back. Good luck!!!
  • jpatrick2jpatrick2 Posts: 17
    I own a 2010 Equinox and have experienced some of the problems noted within this forum, though not as serious as many have. I only have about 50K miles, but just from what I see and read, I don't think this engine is going to have a long life.
    The engine aside, the Nox has been an enjoyable vehicle. We always got decent gas mileage and the ride, features and looks trump most of the competion IMO. That's all well and good, but without a decent engine you don't have much.
    So finally, here is my question. Based on all I've said above, I would buy another Nox if I were certain the 2010/2011 engines problems are history. Does anyone know for certain whether the 2013's have gotten a new engine or the old one modified? I'm speaking of the 4 Cyl. I don't see many posts from the 2012/2013 people that indicates they have the same issues. Any info appreciated.
  • rski43rski43 Posts: 13
    edited March 2013
    .....I dumped our 2010 last May & bought a 2012 w/ V6. Gas obviously goes faster, but all in all enjoy the rest of the vehicle's features like you. They had $1,500 rebate when buying a V6.
  • Hi jpatrick2,
    I was also the owner of a brand new 2010 Enox (purchased July 2, 2010.) At 20,000 miles, many of the problems mentioned on this forum occured to my Enox all at once. Timing chains, engine noises, tensioners, etc. Long story short, my dealer was upfront about the 2010 Enox problems, loaned me a Traverse for 2 days, repaired all of the above mentioned issues, and the car ran much better.
    That said, I have an elderly parent that I visit out of state quite often, and even though the 2010 ran much better, it was still in the back of my mind this car could go bad at any given moment.
    I traded it in for a 2013, and when I started the engine on the 2013, I knew instantly it didnt sound ANYTHING like the 2010. IMO, it sounded like an engine is supposed to sound.
    I have had the car for nearly 4 months, and have almost at 5,000 miles on the odometer. No issues thus far. I am getting MPG's that I NEVER got on my 2010. My 2010 MPG was 22/25. My 2013 is 24/27. I drive 70-75mph on the interstate, so I dont expect to get 32MPG. I doubt anyone really gets 32MPG.
    I, too searched for issues with the 2013 before I bought one, and occasionally search since I bought mine. Thankfully, 99% of the posts were positive. I am hoping since my car is the 4th gen engine of the re-design that I will get at least 5 great years w/ no problems. If I dont, I have already determined my 2013 will be my last GM for the rest of my life. And I have been a loyal GM customer for 30 years!
    Like you, I love the style, feel, design, features, and ride of the Enox so I really didnt want to give that up just yet, either. Thus far I am very pleased with the 2013. I have the base model 4 cyl, and I believe you will be just fine with a 2013.
    Glad to hear you are enjoying your 2013.
    You are right in that the chatter about major engine troubles seem to stop with the 2010's and 2011's. You would think that an alarm would go off at GM after two model years of problems, but time will tell.
    Thanks for your encouraging input.
  • kevinskkevinsk Posts: 2
    my 2010 is doing that exact thing. temp going hot. warning info on dash. no heat from heater.. did the water pump change fix your issues?
    mine doing the same thing. did you ever get the issue fixed?
    My 2010 did something similar a few months ago. The temp guage pegged on hot and I got the over heated warning. Luckily I was close to home. I shut the engine off and the fan continued to run as it would in an overheat situation. However, it was pretty clear that the engine was not in fact overheated. I called the dealer and they sent a tow truck. Ended up being a reprogram to the tune of $44. All is well now and as it turned out, this was just a computer thing and not an actual overheating situation....Which was good of course.
  • kay2316kay2316 Posts: 2
    As far as I am concerned, the car is still not running the way it should be. I will be driving down the road and the engine will start missing. It has not shut off on me again, but I believe it is only a matter of time. I have had the cruise control on going down the highway and the engine starts to miss and the cruise has actually shut off. I just do not feel safe in this car. I would love to get rid of my Equinox, but know I would take such a hit on it. I only have 26,000 miles on it. I cannot trust it to take long distances for fear of getting stranded. I think twice before pulling into traffic just in case the car decides to shut off. I think GM should buy them back.
  • dnydny Posts: 8
    For what it's worth ... has your dealer done an oil consumption test? or have you noticed if the oil level is low? My problems were similar but all were due to a low oil level. You could very well have different problems but I'd want to eliminate the known oil consumption problem as the cause of your stalling.
  • nox10nox10 Posts: 1
    My 2010 Equinox would not go into gear. I was able to pull off the highway and turn the car off, when I tried to turn the car back on its makes noise like a plane powering up and down. Car was towed to a dealer and they suspect it is the transmission. After a complete day of sitting in the service lot at the dealer, car still not diagnosed and all I get is a bunch of excuses. GM customer care is no help and not worth a thing!
  • dan2330dan2330 Posts: 1
    A few issues I have had lately with my 2010 Equinox LTZ. About a year ago the Navigational System clock started to show the wrong hours each time I started the car. Found out just last week that this is a known issue by GM and that it would involve a $60 fix. The problem with the NAV system started to get worse, to the point that now all the saved addresses are gone for the GPS, and each time I start the car the whole radio goes into some sort of reset- The only thing that is consistent is my XM stations are all in memory.
    About two weeks ago noticed the tail of the car was just opened on it's own a few times when parked in the garage. Have no idea why the tail was up it just was.
    And now the engine problems. First indication was about a year ago as it stalled out at a traffic light and the CHECK STABILI TRACK light came on. Car started after re-start and ran fine. About two months ago the check engine light came on and when I got home had a urgent message from ON STAR that the vehicle needed service. GM Service guy said something about using a better grade gas in the car, come again, can it get any better than Premium?
    And now today the car wont even start, the STABLI TRACK indicator came on again, car won't even turn over. Left the car in the garage used wife car to do errands came home and was going to try it again but the door locks won't even open now. Guess time to call GM service again, hope this isn't some bull about better gas again.. :sick:
  • rcurley1rcurley1 Posts: 1
    we have a 2013 Equinox that when we first picked up had an issue when you turn on the car the radio was dead the dealer did a host of things to it and for a couple of months seemed to be good but today it happened again. Has anyone else had this issue?
    Hi nox10,
    I am really sorry to that you are having issues with your Equinox. I would like to look into this for you. Can you private message me your full name, address, phone number, Vehicle Identification number, and approximate mileage on your vehicle please? My email address is socialmedia@gm.com "Attn Crystal" in the subject line.
    Sincerely,
    Crystal L. GM Customer Care
