Pontiac Grand Prix AC/Heater Fan issue
I have an issue with the AC/heater fan that seems a little different from the other threads here. I have a 97 Grand Prix GT without climate control.
No matter what settings I put the fan on, I get nothing more than just a trickle of air out of all the vents (defog, head, feet). When I change the speed settings, the fan gets louder, like its trying to blow air harder, but still nothing more than a trickle of air from the vents. Changing the vent selector doesn't affect the airflow out of any of the vents. If I turn on the AC, it seems like the trickle of air does get cool eventually, but not nearly enough to make the car comfortable.
Has anyone seen this issue, and can point me in the right direction to fixing it?
Thanks for posting, and I'm sorry to hear about this concern you're having with the HVAC. We can look We can look into the situation further (see if any recalls are associated to your vehicle specifically/help you work with a dealership towards resolving this concern). Please email us with your name/user name, contact information, the last 8 of your VIN, and your involved dealership.
Best,
Sarah
GM Customer Service
I'm sorry to hear about the concerns you're having with your HVAC, especially as colder weather is rolling in. Have you been working with a dealership already?
Sarah
GM Customer Service
I'm sorry to hear about your HVAC concern, especially as cooler weather is rolling in. Have you worked with a dealership already towards resolving this?
Best,
Sarah
GM Customer Service
HOWEVER, there are reports that this resistor goes back on occasion because of water leaking onto it from a bad windshield seal, so you should check to see if the resistor is full of corrosion from water damage---if so, you have TWO problems to fix, or you'll be back under there soon enough.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Jim
I have a similar problem and hope to get some help. When I turn on the fan my ac switch/ button automatically comes on but when I press the button it wont turn off. I would like to be able to get heat now that it's getting cold. Any ideas, help and suggestions would be helpful.
