CHECK ENGINE Light just came on after traveling through flooded streets
Good evening,
We had brutal rain in south Texas this afternoon (5.6" in about an hour), and the streets were flooded. Traveling through water up to the axles (2008 Outback) was inevitable... unfortunately. Obviously the engine compartment must have gotten really wet. However, there doesn't seem to be any ill effects: the engine sounds fine, transmission shifts normally, no smoke, etc...
The problem is, my check engine light came on and the cruise control indicator started flashing. Surely there must be others with a similar experience. Should I be overly concerned [about the check engine light]? Also, should I consider any maintenance on parts that the water may have damaged?
Thanks for the help. The Best,
Chad
Chad
It may be worth waiting a day or two and letting everything dry out. I have had similar problems twice and they have resolved after everything dried
Cheers
Graham
You can use WD40 to clean, the WD in the name actually stands for Water Displacing.
Not on any rubber parts, though, which won't like the contact with any petroleum products.
If the plugs went under water I'd probably replace those and the spark plug wires while you're at it. There could be water in those boots that may never evaporate if they're sealed up in there.
We went driving in the Pine Barrens and this particularly crazy guy in a Subaru XT6 drove through deep water and even got water in his intake. Some ad-hoc mechanics removed his plugs, sprayed in WD40, ran the starter a few times to get the water out the engine, and voila! It actually ran again. It was wild.
He did lose his clutch that day, though.
I would go ahead and change all your fluids, to be safe. Flush the brakes, clutch, trans, front diff, rear diff, engine oil, and radiator. Any or all of those could be contaminated if they were under water long enough.
Best of luck.
I also agree with Juice and would want to know the code that was thrown.
Being a 2008 I assume it is still under warranty?
Juice, that crazy person sounds like Mike.
On a previous trip a different Isuzu Trooper had taken in water. The piston rods actually were bent, so they had it towed out and needed the whole engine replaced.
Water can do serious damage if it gets high enough, that's why off roaders use those snorkels.
This afternoon, while running errands, the Check Engine light had shut off and it seemed to be running just fine. However, twenty minutes later, while parked, I smelled burning antifreeze. In the 5 minutes it took me to get home, the AC stopped blowing cold air, and the engine was beginning to overheat (needle wasn't burried).
Sure enough, when I got home, there was a steady drip from the radiator (there was also a mist of antifreeze on the ceiling of the hood as if there was a burst). So clearly the radiator has a huge leak. But PLEASE tell me my engine is fine. I ask this because when it started to overheat, I began to hear a knock when I'd accelerate.
HELP!
Have it towed in for repair, do not drive it to the dealer.
Keep us posted.
I'm not sure how the water would have caused the radiator leak (hot hits cold and sudden contraction causes crack?), but still, be very careful.
Any speculation on the health of my engine?
I'd call 800-SUBARU3 and ask for their advice, also.
This is a bummer, the car is so new.
Whether they cover it or not will depend on what exactly happened, I guess. I'm suer they'll find signs of water so be honest with them, but then again a splash of water didn't necessarily cause all the damage. I hope not.
After driving through flooded streets, my 2008 OB developed an overheating problem. Specifically, after about 5 minutes of driving, when the engine temp gauge is at half, I begin to hear a "knocking" noise that sounds almost like a diesel engine. Then, the temperature gauge shoots up... after that, I don't know because I've only driven it a few times since the overheating problem developed.
The good thing is; I don't think there are any major issues with the engine/head gasket/transmission/etc. In earlier posts I had been concerned with damage to the engine but I've ruled that out as I can't re-create the noise when the vehicle is in neutral (after it has overheated). My impression is that water caused the failure of some electric component which is important in cooling the engine (NOTE: I AM NOT A MECHANIC).
The vehicle is still under the manufacturers warranty so I'll be calling road side assistance for a tow in to San Antonio, the nearest Subaru dealership. If its covered under warranty great, if not, I feel better about having it repaired by a Subaru mechanic. I'll keep you all posted with results in the coming days.
Thanks again for all the help; it is reassuring that there is a dedicated and knowledgeable community of Subaru owners willing to share their experience and $0.02. The Best,
Chad
You made the right call. Good luck.
Most obvious issue would be something caught in the fan blades of the cooling fan. Calling Roadside Assistance is the right idea.
Cheers
Graham
I asked him about the knocking noise that is produced after it overheats and his impression was that it was probably nothing to lose sleep about (unless one drove while it was overheated for a prolonged period of time).
Anyhow, hopefully that is the end of it... $470 later!
Thanks again for y'alls help.
I think you handled the whole situation very well. Hopefully you have many years of enjoyment from this vehicle yet to come!
Definitely change all the fluids.
