Honda Pilot Brake Problems
Discuss them here!
SUVs and Smart Shopper
I have seen this problem reported on some other complaint sites, but Honda denies there is any problem.
Cathie
Mid-summer I experienced the same thing driving with my two children. My husband didn't think there was anything wrong until recently he was driving and it happened to him as well. Have you found any further information regarding this braking problem. If I find anything out I will be in contact.
Emily
I have experiences the same problem twice over the past few months and can not seem to find a good answer on what is causing this. It's almost as if I were slamming on the brakes or the car is braking on its own. Have you received any good insight on this?
Jeff
haven't you experienced your home computer freeze?
I saw this on Car Talk's forum, the person there did get some resolution from Honda, they admitted to the problem, fixed it and gave them a loaner until the car was fixed.
I am curious to know what you all are being told by dealers/mechanics and if there's any good, prescribed fix.
We *just* bought a 2005 EX this weekend, with 74K miles, one owner, well serviced and Honda certified. I would never have bought if I had found these problems before - good grief. Hoping we don't have this problem but wondering exactly what to tell the dealer to look for if we do.
Good luck to all,
Mary
If so, why can't they be turned?
What is the thickness of the rotor?
What is the minimun thickness specification?
They said it exceeded the minimum thickness specifications? Yeah sure sounds good, except I have no idea what that specficiation is.
Minimum thickness reasoning is good to get it changed but how do you know they are telling you the right measurements?
Dan
I have an '08 Pilot EX 4WD with 26K. Purchased used in December. Car runs great. The only problem(s) I have noticed- is the brakes tend to make alot of noise (not squeak/squeal)- but more of a clunk/creak when pressed- I hear it more when I shift from Reverse to Drive and letting the foot off- you can hear it somewhat when applying in normal drive conditions. Have not taken it to the dealer- but the local shop we use inspects and test drives every time I bring it in for service and they indicate brakes are fine.
I did notice back in January the first time I took it for wash- that the entire brake (?suspension) system seem to creak/groan and generally were quite grabby after pulling out of the car wash. My assumption is the brakes are still quite wet after the wash- seems to be a regular pattern with the car wash- again not sure its related.
Any thoughts?
I had it checked out and the computer showed two brake system malfunctions but, no repair was recommended or done due to everything being okay now.
Honda America refuses to do anything since the local dealer doesn't recommend anything be done.
I contacted a local tv station's trouble shooter who made a call to the dealership and they immediately called back and were very interested in my problem but have yet to call with any solution. I will try to keep you posted.
You are the first other I have found with the same problem.
Mike
I would like to know if you ever got any kind of action out of Honda on the braking problem and what the conclusion was as to what caused it. If it was fixed did they charge you? Mine is out of warranty so the cost will be of concern to me.
If you never got any kind of satisfactory response from Honda, maybe we all can by keeping in contact and sharing info with each other. Right now I am waiting on a response from a complaint I filed with the NHTSA and am in contact with the Federal Trade Commission.
Mike
Mike
does anyone has the similar experience?
Is this related to your issue...does anyone else have info on this?
Honda is saying that (based on their inspection at my house) the ABS/VCS/TZS modulator and the brake switch should be replaced on my Pilot and in doing so the repair should correct my concerns with the vehicle. Anyone have any or all of these repairs done and if so, did it work?
If anyone has had the sudden braking again after "repair", please please post. I do not want to get into this vehicle with my family ever again if this repair doesn't work.
The dealership (Hennesey Honda in Woodstock Ga.) had the Honda America (?) rep check it out and they were both on the phone with me (speaker phone) and basically said there was nothing that they could do since they could not duplicate the problem. I guess they are waiting on me to duplicate it on the interstate or in an intersection.
They did recommend to change brake fluid, front /rear pads rotor resurface, change spark plugs and 90k mile check up and a timing belt package for $1869.95 plus tax. They said that the wouldn't even say that this was likely to fix the problem. The last thing that Hennesey said is that they were going to give us a good deal on a used car but, they only have 60 right now and there was nothing that would work for us but they are looking.
More recently, my wife had an unexpected near failure when she had to brake fairly suddenly at a crosswalk, but when I have tried to replicate it, I had no problem at all. So I'm wondering if this is a problem of electronics, and not, say, brake pads.
bjader
Only when we drive up a hill (well-inclined), and before you reach the top of the hill- therefore, stopping due to a stop sign or signal light, the break becomes stiff. It's literally feels like you're stepping on a ROCK. No break pedal movement at all. Accelerator after the stop has no problem, but the service man at our dealer keeps denying our complaint and says that there is no problem.. when this is a serious break problem. The break pedal becomes very stiff; no movement at all. The service man tells me that the break stops since its at the end of the break track, but when it hits the end, the break should well come back up. But it does not; the break remains stiff until I hit the accelerator. I have driven many cars in the past and I have never had this issue before. This is the first time this is happening. And I'm worried that this issue can turn into something serious.
I am going back to my dealer tomorrow morning to discuss this issue with the service manager. I would like to know if anyone might have this similar issue..?
:mad:
To replace just the front rotors would cost $450 to $550. Honda deal said they can just resurface the rotors, but I read that's not usually advised.
I don't use dealers for repairs unless it's a warranty issue, has anyone had anything covered by the dealers on the rotor issue? The Pilot has 45,000 on it!
Does anyone of you know which model years are involved?
Is only the 2005's?
I have a 2006 Pilot with impeccable record. No problems except the AC condenser which was covered under warranty I have had perfect service from my dealer in Brantford Ontario.
It now has 175000 kms. (118,000 miles)
2005 Honda Pilot Probed by Feds for Unexpected Braking
"NHTSA said it has received 205 reports of "unexpected vehicle deceleration and/or steering pull resulting from inappropriate electronic brake application with no brake light illumination."
Sounds like it involves the Vehicle Stability Assist system on ~87,803 Pilots.
Read the manual. The brakes self apply when you are stopped pointing up hill when you take your foot off the brake to place your foot on the throttle so the car does not roll back until you can accelerate.
The brake pedal does go hard when this is active.
Not a problem...a feature.
The first brake job for warped rotors was partially warranty and I paid for new pads at only about 26,000km/16,000 mi.
Car shuddered and steering wheel shook when braking, particularly downhill.
This can be intermittent as the rotors cool and sometimes straighten then warp again.
these are the standard symptoms of warped rotors.
the next was about 45,000km/28,000 mi.
I don't drive like a loon.
Turns out they only turned the rotors the first time so they replaced them under warranty and now with 78,000km/48000mi they are still solid and smooth so i suspect the initial stock rotors turn into potato chips pretty easily.
A tire shop now tells me I need a brake job within 10,000k/6,000 mi and have quoted total replacement of all parts for about $1,100-1,200.
I suspect new pads and turning the rotors will suffice as they are usually good for 1 turning and they are not warped.
The newer pilots have 18 inch wheels whether for better ventilation, maybe bigger rotors and clearance or just style i dont know.
The stock rotors were definitely weak as i have not had this happen before except with a craapy caravan fairly loaded on a big hill at barely 21,000km, 1,000 km over the official brake warranty on that one.
Dodge covered nothing by the way.
If Honda is paying get the new rotors and all should be well.
Odie
Odie
Has anyone had problems with the recall repair for the 2005 Honda Pilots which came out a year ago?
