2010 Chevy Equinox Power Seat Problems
                    Has anyone seen the bulletin on the memory seats for the 2010 Equinox? I bought my 2010 Equinox LTZ 8/4/09 and have nothing but problems with it. The memory issue was just the latest of my problems and GM's laughable bulletin explaining it was a joke. Apparently if the seat is moved from a different position than what you have programed in the seats will go back to that position and not the one that your keyfob should be programed to go to (i.e. Memory position 1 or 2) the only way to fix this is to manually reset by pressing the 1 or 2 on the seat when you get in and that will fix the problem. I was told by the GM rep that while this is not the way it was intended to work it that the seats are working the way they were designed. Just what the hell is that supposed to mean? Also this not only effects the way the seats work but the position of the mirrors as well.
My 2010 Equinox Blog
Best of luck to you!
