Pimp That Nox
So how have you dressed up your Nox?
Me, so far I've.... painted the muffler black, added the towing hitch, a stainless exhaust tip, splash guards, SilverStar Ultra high beams and last night I installed this little gem.
http://www.shopsar.com/ProductDetails.asp?ProductCode=1336-0185-10Q&click=2
Stainless steel grill. Makes the front end a little classier than the black plastic mesh.
Also, how has your mileage been? Do you think the grill might effect air flow, thus hurting your mileage a bit?
I plucked the grill off eBay at a big discount from the current price.
The grill was not an easy job. They promote 60 minutes, plan on more like 4 hours. You can't have big forearms because there is very little room between the OEM grill and the radiator. Both arms were pretty scratched up once I was finished. You have to pry the top half of the grill away from the body and hold it in place with shorts 2x4s.
There is very little design tolerance in the fit which makes it that much more difficult but that much nicer too, once it's in. Getting it in place without scratching the existing chrome takes patience and lots of masking tape to protect the chrome. At first I thought the new grill was too wide to fit and actually called to return it. The upper lip has to slide under the inside upper lip of the existing grill, then it pops right into place, but they didn't mention that in the instructions.
Also you need a really odd size thumb ratchet 11/32 or a ratcheting box wrench to turn the tiny nuts on the back side. There's not a whole lot of room for a small socket wrench. I found the 9MM works well enough.
They arrive 12/8 and i will inform ya'all if they fit. Tire height is 28.66 vs the Nox's 28.52 which is damm close. front rims are 8 wide with 35 offset vs Nox's 7.5 wide with 40mm offset. rears are 9 wide with 40 offset. Looks like they are going to fit. There are about 20 sets of these on ebay all the time and the sell for $950-1200
Wish me luck. Also I was going to put SS silverado brake duct bumper vents in the place of those ugly plastic non foglight hunks of crap, but can't find a body shop brave enough to do it.">
Manufacturer says it takes about an hour. HA ! After about 1.5 hours I gave up, called and explained it didn't fit and wanted to return. THEN they give you the real instructions. Just dry fitting it, it looks to be too big for the opening. The top edge has to be pressured upward in order to slide the bottom into place.
You have to pressure the original forward and hold in place with pieces of 2x4. If have large forearms, look for a little helper. There isn't a whole lot of room behind the grills to work the nuts on the compression screws. 2nd time around it took about 1.5 hours. Also, it really helps to have a thumb socket to turn the nuts. It's real difficult keeping a small wrench on those nuts.
By the way, those 20's will screw up the recorded vehicle mileage since one full rotation will be longer than the smaller wheel. The recorded mileage will be less than actual. Just keep that in mind for your service records..
