1993 Eurovan Lock cylinder switch
bshayesteh
Member Posts: 2
We really have to remove the full lock cylinder, not just the switch and it is not clear what we need to do. Thx.
There is also a warning panel that states "If the brake warning light does not go out with the engine running and the parking brake released or light up while driving, the fluid level in the brake fluid reservoir may be too low. This may be due to a leak in one of the independently functioning brake circuits. If the brake pedal travel has increased, one of the brake circuits may have failed. Avoid driving the rehicle and have it towed to VW. If the brake pedal travel has not increased and braking performance remains unimpaired, proceed to your VW dealer."
If you have ABS, the symbol will have a small ABS in the middle instead of the exclamation point.
I also found a reference to a small circle with lines radiating from it, like a sun graphic and that has to do with the ambient temperature reading, which we do not have. Hope this helps.
It looks like others here have experienced similar problems. Before I order a new ignition switch, can anyone help me feel more certain that this, in fact, the problem?
