Towing a 1995 AWD Impreza
robdog13robdog13 Member Posts: 8
edited March 2014 in Subaru
I'm looking to tow a 1995 AWD impreza using a tow dolly and wanted to know how i need to do it. Are there any drive shafts or linkage that needs to be removed or adjusted ? Thanks for any info.
    Manual or automatic?
    Manuals can be towed with all 4 wheels on the ground. The visous coupling allows for enough slip.
  • robdog13robdog13 Member Posts: 8
    It is automatic. Thanks
  • xwesxxwesx Member Posts: 16,780
    How far are you towing it?
    About 325 miles. Texas to Arkansas
    Okay, then if you are towing with the rear wheels on the ground, you should remove the driveshaft between the rear axle and the transaxle.
    Thanks alot.
