Chevrolet HHR Noises and Vibrations
bobthebike
Member Posts: 11
in Chevrolet
Hello: Upon cold starting the HHR, it makes a "gurgling" noise from behind the dash. Weird, but it disappears a few miles down the road. The temperature guage always reads normal and I have no wet spots in the interior. Any ideas on what it could be? Other than this little quirk, the HHR is one fine little ride! ,BK
There is an issue with the fan blower getting wet
But is the water full in the reservoir tank for the engine coolant. Check when cold because the tank is under pressure. A low coolant level might cause gurgling as the coolant is pumped through the heater core.
http://townhall-talk.edmunds.com/direct/view/.f1d1639/0#MSG0
This liink is about water leaking into the heater box through a cover that loses its seal. Although it's unlikely that water slushing inside the heater/ac box is causing a gurgling sound, someone else may benefit.
2018 VW Passat SE w/tech, 2016 Audi Q5 Premium Plus w/tech, 2006 Acura TL w/nav
Thoughts?
The latest humming/roaring noise was explained by my dealer as bad tires. I got new tires and the noise remains. Bad front wheel bearings diagnosed today at 64,000 miles. No warrantee and I'm out about $900 this time. I am so disappointed with this vehicle and for buying American made - had Toyotas all my life and never had problems like this.
