lincoln zephyr traction control
                    My daughter has a L Zephyr with traction control , I read the-manual and its very confusing on that particular item, should the switch for the Traction cont be on or off while driving on a normal good dry road ?">
The Traction Control switch is
located on the instrument panel.
The Traction Control system will
automatically turn on every time the
ignition is turned off and on. The
Traction Control system should
normally be left on.
If you should become stuck in snow
or ice or on a very slippery road
surface, try switching the Traction
Control system off by pressing the
switch on the instrument panel. Switching the Traction Control system
off may allow excess wheel spin to “dig” the vehicle out and enable a
successful “rocking” maneuver. When the Traction Control system is
off, an indicator light will illuminate and will remain on until the system
is turned back on or the ignition is turned off and on.
The link above provides more information.
[ this is what the articles states ]=Traction control on the V-6 test car was just right -- perhaps unique in all the industry," Healey wrote. "It allowed tire spin when starting forcefully on slick roads and gradually eased the spinning without trying to stop it, allowing the car to keep moving forward as traction was gained. It should be unusually effective in winter
With this system, it is unlikely you will become stuck unless you are driving through the deepest snow on unplowed streets. In that case the bottom of the car will drag and you are probably not going anywhere, anyway. As for taking off on ice, even on an incline, a light foot on the gas and the traction control system left on will likely get you moving.
Again, leave it on and let it do it's job.
Why,? the red light comes on only when you turn the traction switch to OFF,you would think this should be the opposite to let the driver know its on,however it [the traction control] is on when the car is started again and the light stays off. .Thanks so much on your efforts to help me with this I really appreciate it.
