95 impreza 15 MPG So bad need help
So i just did a complete tune up on my 95 subaru impreza, changed sparks and plugs, changed oil/oil fiter, changed fuel filter, air filter, fixed exhaust leaks, and im still just watching my fuel gauge go down so quickly! i need some help if anyone can suggest something else please? i believe im getting like 13 to 16 MPG and i'm not leaking anywhere.. HELP
thank you guys!
Next thing would be the ignition coil itself, which sends out the spark.
Spark or fuel, and you said you already did the fuel filter. If power is OK it's not the fuel pump (it would hesitate or stall).
You may want to do a compression test on all the cylinder to see if one of them is not sealing properly, if so 25% of the energy from the fuel is wasted, and it's basically running on 3 cylinders.
When they do that, look for no more than 10% variance in the pressure in all 4 cylinders. If one of them is more than 10% lower than the others, there's your culprit.
I would start with the vacuum system - make sure you do not have any leaks or blockages. If so, that can cause the car to think it is running lean and dump more fuel into the system.
If you are not getting a "check engine light," it likely means all your sensors are at least working.
Do you possibly know how to do a compression test or should i look it up online? ive just spend a good deal of money on this car and would rather do everything myself. Oh and also i just replaced the alternator, idk if that has anything to do with the fuel consumption but it doesn't seem to be helping what so ever. I have a 13 gallon tank, which looks beat up as if someone hit it when running over something so lets say i have a 11 gallon tank. just recently i was able to get about 210 miles out of it. it was a lot worse before the tune up and the lucas injector cleaner. And the 210 miles were basically all highway so im pretty sure im getting garbage for mpg
I believe you put the cylinder at TDC and slowly add pressure to see what it'll hold.
It's not going to be too easy because of the tight clearance to where the spark plugs are.
This will tell you if the gaskets are failing and leaking, though.
