300 2.7 question
I am looking at a 2006 Chrysler 300 base with the 2.7 liter V-6. My question is, are these motors any better than the horror of the 98-02 version of the same motor?
It is a good engine with proper care and the proper oil. My wife has a 98 Concorde LX with the 2.7 and except for a leaky oil pan gasket and a PCM update, the engine has been bullet proof.
Oil is changed every 4000 miles and we use a good synthetic like Amsoil or Valvoline SynPower 10W-30. Avoid Mobil 1. The timing chain tension is controlled using oil pressure and there is a filter screen that must be kept clean. If that sludges up, you are screwed. The 4.7 V-8 uses the same system.
Do a detailed search on the "net" on the 2.7 engine. ----- Make your own decision based on this investigation! --------- Best regards. -------- Dwayne
