Lexus RX 350 Headlight Removal
Can someone help with how to remove a headlight from RX330. My headlight has water forming inside. I have found two bolts on top and one bolt under outside. Looks like there is a black plastic clip (maybe 2-3 inches wide) on the under side connected to the bumper. Do you have to remove the bumper? After removing the three bolts, there is still something holding the headlight. Any guidance would be greatly appreciated.
Joe Evans
Joe Evans
Joe
Lexus just came out with a recall that calls it " Good Will" They will replace your 2004-2008 defective $1480 headlights free of charge. If you have replaced them at your expense, Lexus will reimburse you. The problem with moisture in headlight is that the dripping moisture corrodes the ballast and headlight bulb goes out. Contact your local Lexus dealer for direction.
