2001 Dodge Ram Truck idle problem
I have a 2001 Dodge Ram has an intermittent idle problem. When started it will immediately die. I have to give it some gas to keep it running. After I drive for a while, from 3 to 5 minutes, it will idle again. If I pull up to a stop sign or light, I have to shift to neutral and keep reving the motor to keep it running until it wants to idle on it's own. There does not appear to be any specific conditions as to when this will happen. Somedays it does not do it at all. Other days it happens first thing in the morning and other days it happens in the afternoon. Any ideas on what to do would be appreciated. Thanks. I had the fuel pump replaced about 6 months ago so I do not think it is the pump. It has about 138,000 miles on the engine.
1 Weak or failing battery. The PCM can be sensitive to low battery voltage. With engine running battery voltage should be 14v plus or minus 0.2v A battery that is over 3 years old should be checked first.
2 IAC or idle speed motor. Located on back side of throttle body. I think it's held in with Torx head screws
Corkscrew
Corkscrew
