Pontiac Torrent IAT wiring diagram
waterboywt3wd2
Member Posts: 2
I am looking to connect a performance chip to the IAT (intake air temperature) sensor and ground wires. Does anyone know the color codes for these wires (located on the air breather pipe. There are 6 wires in the plug I believe. The Torrent is a 2008 with a 3.4 V6.
Thanks in advance,
Dave
Thanks in advance,
Dave
link
Try saving it to your computer and you should be able to enlarge it a bit (and hopefully it'll still remain legible).
Thanks for trying, but I can't make out the writing well enough to connect the unit. I think the IAT sensor is at the bottom of the diagram and is a tan colored wire but I also need the ground wire in the plug which I can not make out.
Dave
