GMC Yukon XL Normal Oil Usage?
We have an '07 Yukon XL that is using 2-3 quarts of oil every 3K miles. Our local service tech states 1 quart per 1500 miles is normal.
I have friends with similar (2007-2008), not exact, vehicles that don't use any oil and put more miles on than us.
We live on the great plains of ND (i.e. easy driving), mainly carting kids around town and driving to work (my wife's vehicle.) I use it occassionally to tow my aluminum fishing boat (couple times a year tops.)
Yukon now has 44,750 miles on it and this issue began around 30-35K.
We just had it serviced and no leaks were detected. The obvious smoking signs are not there for burning oil either. We are beginning a 1,000 mile check with the dealer to see if the oil use is "excessive."
Anyone else using oil like this, is it really "normal" and are there any thoughts out there regarding this.
Bottom line, it doesn't seem "normal" to me. Thanks in advance for your input!
Another person with the same problem! Your message center tells you that the engine oil is low - add oil, right? I have had my yukon in 4 times for this problem and actually GM knows about it . They have replaced the head gasket, rocker arms, lifters and it is currently as we speak in the dealer for perhaps replace the rings and pistons. I am actually looking for a COMPLETELY NEW ENGINE! I LOVE my truck and am not planning to get rid of it, but even though I have an outstanding relationship with the service manager, I feel very disappointed and feel like the engine has been "molested" if you will enough! It just turned 36K and this seems to happen every 2K. My guy said that after the lifter repair they usually don't have any more problems and that my vehicle has gone the farthest with this. He said that it is a BIG problem with the Chevy Suburban and the engines were "shared" at the plant on this one particular day of production. The Chevy dealer across the street is getting created motors and replacing them left and right.
Mine used 1 1/2 quarts every 2K. 1 quart is normal, yes, but why then does the warning message come on? I hope you don't have to go as far as I have.....I really do LOVE my truck.....
I was told by GM (Heather) that they could not guarentee that replacing the engine would fix my issue and that the techs where looking for a solution. My guess is they do not want to spend the money. SAD SAD SAD. I have had GMs my whole life and now they wont take care of me. 100K power train warranty???? Don't make me laugh. What a joke.
Unhappy with this situation. They should back their product a little more than this. Good luck on your truck but mine is never ending.
I am ticked at them right now and would love any more new info to throw their way to get the new engine. I also love my Yukon XL but this is getting to be to much. Also my performance and MPG is not what it used to be.
I have 2007 Yukon XL with oil consumption issue. It started at about 32K miles. I now have 40K.
Dealer has been reluctant to confirm that it has an issue, but has replaced Right Valve cover in February of this year. This did not resolve the issue. The Dealer next step was to change the driver side valve cover now.
Before I had the opportunity to schedule time to replace the left side valve cover on a trip to San Simion, CA my car started to misfire and I got a "Stabilitrack Service Light and solid engine light" on dashboard.
This Monday I took my Yukon back to the dealer. To make a long story short...the dealer is now replacing the rings on my Yukon.
I hope this correct that issue. :-(
They have just completed a replacement of Pistons, Rings, and Rod Barings. I am not sure if this will work but I will let you know if it does not. Unfortunately my windshield was broken during the being put back in and the bumper was damaged, so I am waiting to get those fixed by the dealer. I will let you know what happens.
Hoping this work.
I am from GM Customer Service. Please let me know if the fix your dealership is currently doing takes care of the problem or not. Thank you,
Mariah GM Customer Service
Although, I am pleased that "alot of work" is being done to my Yukon to correct this oil consumption issue... I wonder what impact this "engine overhaul" will have on life line of my vehicle?
I am glad that the dealership is trying to fix the situation with the oil consumption. I would think if they are fixing the vehicle for the better that it would prolong the life of the vehicle, and not hinder it. Thank you for getting back to me.
There was a change in procedure to fix the oil consumption issue on my Yukon XL 2007.
The Dealer/GM recommended to replace the engine instead of the valve cover and ring job.
I picked up my vehicle on Wednesday. So far so good.
I hope this fixes that problem and I do not continue to see any others.
It seems to me like this oil consumption issue is real, and by the looks of this blog and many others that this is in fact happening to other GM and Chevy vehicle owners.
Why is GM so hesitant to confirm that there is a problem with “high oil consumption “on certain vehicles? By now there should be a bulletin addressing this issue and a procedure to correct it.
Instead, we have to endure months on wasted time and aggravation of having to argue and plead with service managers before we are forced to contact GM Customer Service directly before anything gets done.
To add to my frustrations, I had to tolerate the service manager complaining of me opening a case with GM customer care when I picked up my Yukon. Very unprofessional!!! Not what I expected from GM.
I have the above mentioned vehicle with about 94K miles that I bought used from a Chevy dealer in the Portland,OR area at roughly 46K. This Suburban has always burned oil and to degree I accepted it because it was used. But 2 things really get me, 1) the dealer never gave me a service history (my bad) and 2) I found out from my local Chevy dealer during a service that it had the transmission replaced, now I'm finding out that what I thought was just another issue I inherited is really a big deal.
This is my 4th suburban in about 11 years, I have been a faithful suburban owner and I am now at a loss.
My question(s):
Is there an official Service Bulletin?
Is their an official protocol set-up to deal with this issue?
I use my Suburban for business and I cannot be without it for an extended period of time, with this vehicle at almost 100K miles I'll probably look for a new one in the fall, but not if i don't receive some type of explanation and resolution. Just seems like something else was kept from me by the GM family.
Thank you for your help, please feel free to contact me at any time.
Coupdevill
There are published Engine Oil Consumption Guidelines and specific instructions to dealerships on how to properly inspect for excessive consumption and how to properly measure consumption over time. I apologize that the situation with the service manager wasn’t a better one. If you have any further questions please email me. Thank you,
I guess I should contact the dealership and ask for a service report on this truck to see what all has been serviced on it....well reported as serviced.
I am really hoping I am not going to have to jump thru hoops like some of you have. I will NOT be a happy camper. I love Chevy/GMC products, but if they do not back their product properly....remember one thing.....word of mouth is the the best marketing tool so watch out! Make good on your product GMC! :mad:
:lemon: ?????
I appreciate that you have been such a loyal customer. I apologize that you are experiencing concerns with your vehicle. Can you please email me at socialmedia@gm.com so I can look into your situation further? Thank you,
I apologize that you have had concerns with your vehicle. Can you please email me so that I can look into your situation further? You have to click on my name to get to my email address. Thank you,
There are many of us that are unhappy. I know of the people that had the engine replacement, they are all happy. I know that the trouble with the 2007 Yukon, Yukon XL, Sunburbans, Avalanch, and so on. They where all built on or about the same day. This is obviously a bad engine batch. I have been through the PVC change with valve cover cleaning, New Heads, and now new Pistons, Rings, and rod bearings. The dealership wanted to replace the engine but GM will not allow them. I just got it back after the Piston replacement. If it still has oil consuption issues, I have been told they may offer a me some compensation and allow me trade in allowance on a new one. BUT, I would have been happier with with the new engine. It would have also been cheaper at this point for GM. Why can they not admit a recall on this. Some of the people I have know have had rods go though the block on their 2007 and they got hurt because of it.
What are your thoughts? Heather my rep has not been much help. Let me know.
I apologize that you are still experiencing concerns with your vehicle. Can you please email me your case number, so I can look into your situation further? You can find my email by clicking on my name. Thank you,
I have had the same problems with my yukon and am at he same place you were with the engine out and they are going to put pistons and rings in it, but they can't find the parts. I was just wondering if the gave u any information about the procedure number they were working under so i can get my dealer to to the same
thx
They have to do that test in order to see how much your vehicle is consuming, and whether it is/not within specs for the vehicle. That is just a step they have to follow to see what is going on with the vehicle. Thank you,
I am now starting to experience an issue with the idle on my Yukon XL. I have to have another oil consumption test hear soon.
From what I am reading on here the only thing that will correct the problem would be a replacement engine!
In conclusion, i believe that the oil change may have been missed upon final inspection of the vehicle before sale. I think that they may have billed it out correctly , but may not have performed it. With the oil level low, and the dark coloration, that is what i conclude. I would like to know if the customer should receive the print out of work completed on the vehicle for the GMCertified inspections. We did not receive anything of such nature. The gas tank was at about 1/8th capacity, which i know full is "recommended" and i did not expect full, but 1/8th? Also, the inside of the vehicle was the same as when we test drove it, not detailed or vacuumed once more. I do worry about other things that may not of happened in the preparation of the vehicle that i may have issues with later. I do like GM products, and have had several, one which i had purchased from this same dealer. After my experience, i don't believe i can go back to them for service or sale of another vehicle. I believe i can take my vehicle to any certified dealer for service during the warranty time. I spent a lot of money, almost 29500.00 to be exact on this vehicle, and was very disappointed in the evaluation, and treatment of the situation that had occured. To tell me they will keep an eye on it, yet charge me for an oil change that according to my vehicle said 66% life on one screen, and low level add oil on another. To me this sounds like they had no idea, and changed the oil to see if it will happen again. Not a very secure feeling for a huge investment to me and my family. I hope GM reads these posts, and will try to make things right. After reading some of these other post, my troubles may be just beginning. Good luck to all involved. Thank you for taking the time to listen to my complaint.
I would like to share with you a disappointing experience with one of your GM certified vehicles. My wife and i recently purchased a GM Certified 2007 GMC Yukon XL from Amesbury Chevrolet in Amesbury,MA. After driving the vehicle for 2months approx. 2500miles, there was an onboard message to add oil, oil level low. The indication on the vehicle was 66% life in the oil at the time. I checked the cold level of the oil, and it was extremely low on the dip stick, as well as a deep brown color. I took it back to the dealer, adn proceeded to have them look at it for diagnosis. About 1 and 1/2 hours later they come out and tell me the industry standard is that the truck can burn 1 quart of oil in that time frame and it is acceptable. Now, my wife transports 1 1/2 yr old and a 3 1/2 yr old and drives to work. That is what we use this vehicle for. No hauling or towing is involved, which then i would except the facts as they may be. After telling me about the quart of oil, they proceeded to tell me that they will watch my vehicle every time i bring it in. Does this mean i have to bring in my vehicle every 2500 miles for an oil change? I am not sure that this is the Image GM would like to have for there vehicles. After telling me this, he handed me a bill for my oil change as well. Which after some persuasion from myself, i was able to have him rescind the bill for the oil change.
In conclusion, i believe that the oil change may have been missed upon final inspection of the vehicle before sale. I think that they may have billed it out correctly , but may not have performed it. With the oil level low, and the dark coloration, that is what i conclude. I would like to know if the customer should receive the print out of work completed on the vehicle for the GMCertified inspections. We did not receive anything of such nature. The gas tank was at about 1/8th capacity, which i know full is "recommended" and i did not expect full, but 1/8th? Also, the inside of the vehicle was the same as when we test drove it, not detailed or vacuumed once more. I do worry about other things that may not of happened in the preparation of the vehicle that i may have issues with later. I do like GM products, and have had several, one which i had purchased from this same dealer. After my experience, i don't believe i can go back to them for service or sale of another vehicle. I believe i can take my vehicle to any certified dealer for service during the warranty time. I spent a lot of money, almost 29500.00 to be exact on this vehicle, and was very disappointed in the evaluation, and treatment of the situation that had occured. To tell me they will keep an eye on it, yet charge me for an oil change that accordind to my vehicle said 66% life on one screen, and low level add oil on another. To me this sounds like they had no idea, and changed the oil to see if it will happen again. Not a very secure feeling for a huge investment to me and my family. Thank you for taking the time to listen to my complaint.
My only hope is that GM will protect people like me inthe long run to preserve the quality of there vehicles. It seems from these posts that others are having severe issues, and mine are just starting. Do you know of any protocol or recall on these engines?
I guess I will have to call and complain every 3000 miles when oil must be added to my engine or get a good lawyer since GMC is refusing to address this issue! They said my service department didn't recommend replacing my engine but my service department says they cant replace my engine without approval from GMC!
My friends who also own a 2007 Yukon & a 2007 Suburban are also having the same problem with theirs! Come on GMC, just fix them!
I did receive your email and did respond to your concern. Thank you,
I like :lemon: Lemons :lemon: but only in my Lemonade!!!!
I like :lemon: lemons :lemon: but only in Lemonade!
I apologize that you are experiencing an issue with your vehicle. Have you had anyone diagnose the concerns on your vehicle? You can have an oil consumption test done at the dealership to see whether your vehicle is operating within specs or not. Thank you,
Thanks and no need for an apology. I just hate it when the GM Reps get defensive and you are only trying to convey a real issue that you and others are having.
I called the GM dealership near me and they explained that I would have to have the oil changed there and come back to the dealership every 1000 miles to have the levels checked. The service rep said that after 3000k the oil level was low they would do it again to see if it is happening every time.
The problem is:
1. I don't live near a GM Dealership
2. Going back every 1000 miles will be a pain and very time consuming
3. I don't drive my truck that much so going 3000 miles will take some time.
The Rep also stated they could check my Stabilitrak while in was in the shop then they tell me I can't bring it in until the 12th of July?!!!
Meanwhile my Stabilitrak is going BANANAS. This is CRAZY!
Question: I bought my Yukon when it came back off lease, so that would mean GM did all the service on this vehicle, How can I get a history report from GM on my vehicle's service history? I want to see if these problems have been reported before and they are just on going issues.
I love :lemon: lemons :lemon: but only in Lemonade
The dealership it was leased from would have performed all the maintenance and fixed any problems that may have arised with the vehicle. They would have the detailed history report of what has been taken care of with the vehicle. If you want to email me your VIN I can look into what has been done with the vehicle. You can get my email by clicking on my name. As far as the oil consumption test that is unfortunately how they have to do it. I understand that you live far away from the dealership but, in order for them to determine how the vehicle is operating that is the test they have to perform. If you have any further questions please let me know. Thank you,
I feel like I should not be driving a car that pollutes 2 quarts of oil....every 600 miles.
2 Quarts in 600 miles is UN_SAT!
Thanks Again.......... Mariah GM Customer Service
You're welcome!
- Mariah GM Customer Service
Looks like I will be stopping by the dealer to fill up with oil and top off the gas.... and change a plug. What does a NASCAR pit crew rent for?
2 quarts in 600-700 miles, I thought, would be a no-brainer qualification for a drastic fix for my suburban.
Massive if you think about it. If GM sold 500,000 SUVs (a portion of all their business) and each burned 1 quart every 2000 miles, and with a driver having an average of 12,000 miles a year -- my math says we would have 750,000 gallons of oil somewhere we don't want. Throw in my 2008 suburban at 2 quarts every 600-700 miles, which I am trying not to drive, and GM and I would be responsible for over 8 gallons a year (at its current unfixed state).
I will sell the car instead of going through endless oil consumption test bs.
But I would not pay for them to fix the Valves as that is not likely to fix it anyway. Because you are still under the 100K mile warrenty.
Let us know how things go.
