Head Rests
Any time the seat back is near upright the head rest is constantly beating me on the back of my head and causing me pain in the neck. This is no matter what height I adjust it to. I have a short inseam, 29", and plenty long arms, so it is not like I'm putting the seat back too far ahead. I've come to the conclusion that it was designed for knuckle draggers who drive laying down from the back seat.
I asked the dealer about turning them around and was told they could not be. This idea was someone else's from over in the KIA Rondo forum because it is a major issue with that vehicle as well. Just check out the number of posts.
From desperation I made some new attempts at removing the headrest and turning it around. It turns out there is a lock on the second post that stops it from coming all the way out. You may have to depress both, simultaneously.
It is not a cure for the bad design, but it will stop it from beating the back of your head. That is removed, turn it around and shove it back in. The locks do not work and it will want to go all the way down. I'm toying with some ideas to stop that from happening and will post back if I find resolution.
BTW, my neck is starting to get slowly better and still need pain killers later in the day. This design is as dumb as the guy who sits on his wallet all day and then can't figure out why he gets pain down his leg. ;-)
more than it would like to. I.e., I was uncomfortable.
I can't say I feel that now: I don't remember feeling the headrest
pressing at my head last time.
The solution: a strongly lifted lumbar support and adjusting the seat
position, including the angle between the seat and back. Essentially,
my rear end now dives into the angle so that the back, supported by
the lumbar support, positions my head away from the headrest.
When I got the 2006 Maxx, this past August, its seat felt pretty
uncomfortable to me, compared to the 2005 Bu's. (While it looks
similar, there is something in it that makes it different somehow.)
Not anymore: after many adjustments of angles and shifts, my Maxx's
seat is not at least as comfortable as the ones in the 2005 sedans.
You may want to try and follow my example.
The forward angle of the headrest is hear to stay, it is to aid in minipal whip lash, so it is what it is in many brands of cars. if the weren't designed like that we would be complaining of "poor designed headrest in a whiplash situation". Enjoy your Maxx, there are other things to worry about. :shades:
There is supposed to be a natural arch to the neck and no matter how you position the seat back these rests will force your neck into an unnatural position.
I suspect this is another case of the test dummy not talking.
Write to your congressman because it is NHTSA that imposed stupid design.
What is AWB?
Maybe it is time to take another look at that NHTSA specification. I know there are specifics in it such as related to height of passenger, angle of headrest, etc. If GM has gone beyond the spec, maybe we can force a NHTSA recall & have them replaced.
More on the 11 Lacrosse. But there is also the issue of rather poor back support from the seat. It is like they designed the seat for two adjustable supports and then decided to install only one because it moves up and down. The problem being it can not be in two places at the same time. If you set it for lower back, then you get a sag for higher up the back. If you move it up, the support, then you get a low back sag. I've had the dual pump up bag back supports in a GM and this change is junk. I'd rather have the very firm leather seats in a Malibu which give much better support.
Buick you hear that? So in at least two areas of creature comfort the lowly Malibu beats the Lacrosse. Make that three since you brag about Buick quiet tuning. On some surfaces, the road noise is much worse in my CSX.
