Revs dropping and rising again. Help !
I own a 2000 Outback. The problem I have with it is intermittent.
What happens is that travelling at any speed, the revs drop from 2k to 1k then back again. It hasn't done it for the last week until today.
I have replaced spark plugs and leads, fuel filter,PCV valve,air filter and all hoses are good. The check engine light doesn't come on at all. What could it be ? Anyone shed any light on what it might be ?
Don't worry, it's easier than it seems. This was an $80 item for my 98 Forester.
Car has been running ok, but it still has a few rev drops here and there.
Someone did tell me about using a product called ' Seafoam '
Thank you both for the info about the ignition coil.
Plugs and leads.
PCV valve
Fuel filter
Air Filter
IAC valve cleaned
MAP/IAT cleaned
Throttle sensor cleaned
There are no vacumn leaks and no check engine lights. Oooh I tell a lie I did get a P420 - catalyst below threshold but that went away
The car is not exactly the same, but when the engine does decide to drop in revs, it's like the brakes going on and so sluggish. You can press that throttle and nothing happens. If you pull over to the side of the road and switch the ignition off and leave it for 5 mins or so everything seems ok again. Stumped and pi**ed off.
I got a misfire code before mine went bad (at about ~9 years of age), though.
A very good idea to put the trans in neutral, will give that a go next time it happens.
Thanks for taking the time to answer me.
So to come to a decision engine or transmission. It is the engine.
The P0420 code may be indicative of an issue with one or more of the oxygen sensors (though I wouldn't replace those on a whim given their cost); I am not sure exactly how feedback from those sensors plays into the engine's operation, though - perhaps fibber2 (Steve) could help you out in that regard.
At this point, I am leaning toward the throttle position sensor.
A bad earth - maybe ?
A faulty ignition switch or a shorting relay ? A loose/broken/breaking wire somewhere.
Going to have a good look tomorrow if the weather is good, the rest of this evening going to study a few wiring diagrams to confuse myself even more.
Actually you mention the TPS. That's located at the top of the pedal and comes in one unit. That is a good idea. Thanks for the prompt in that direction 'cos the PCM needs that for timing and fuel injection. Smart one areally good idea.
Dealer fixed it for 350 total.
Hope that helps!
Bad ground is also a possibility. I have heard quite a bit of discussion amongst enthusiasts about Subaru vehicles being poorly grounded. That should be easy enough to eliminate as a possibility, though, just by running a grounding strap from some point on the engine block to the firewall or fender.
I'm in the middle of looking at wiring diagrams to see if the PCM has a ground along the line somewhere.
Also want to try and checkout the ECT sensor somehow, as I've heard that this could be a major cause. :confuse: .
I doubt that it applies here. P0420 - Cat efficiency below standards - is a code usually triggered if the downstream oxygen sensor doesn't think that the cat is properly cleaning up whatever hydrocarbons are being produced.
The front sensor directly relates to engine performance. When I had trouble with one of those, there was stumbling and other driveability issues as the system kept tweaking mixture, timing, etc., to reduce emissions.
Whatever does get produced should be cleaned up (assuming it is not excessive) by the cat. The second O2 sensor is then a monitor to be sure that the cat is doing the job. I don't believe that It does anything to engine performance - just monitor and report.
Have had a look underneath and can't see anything. My next project is to change the coolant before winter and at the same time change the ECT sensor while I'm at it
Have heard that this has a major part to play in cooling and vehicle running. No my vehicle isn't overheating, well the temperature gauge doesn't say it is.
Oil was leaking from the sump pan gasket on to the exhaust and that's what the smell was. Why would this be happening? it's like it is under pressure or something like that
