Thermostat for Tahoe
my Tahoe temp gauge just started moving the other day, only two notches on the gauge but i know this will lead to something. weird this is after a few minutes it goes right back to dead center.... could this be a stuck thermostat?
Filled w/coolant, waterpump working, thermostat working, temperature sensor working.
new thermostat= check
temp sensor?
maybe the waterpump?
just changed the thermostat....cranked it up got to 210 blew cold air...as soon as I started to drive off then heat was coming through..... could it be that the waterpump is starting to go?
When water pumps go, they will usually leak, and if you don't see it leaking on the ground, then you would eventually notice that the reservoir is low and needs refilled. You don't mention loosing coolant.
If you still are having your gauge varying, then you may have a bad head gasket where the burnt gases, are leaking thru the gasket and into the cooling chambers. So instead of your radiator being completely full of coolant, you will always find air. These bubbles of air in the system, can cause blockages and swings in the gauges as the sensor detects the temperature of the air, followed by detecting temperature of the water. This problem can create higher than normal pressures in your cooling system, blowing hoses and radiators. It also allows coolant to leak into your cylinders and engine oil, potentially causing huge problems to cat converter and engine and bearings.
