2010 Forester XT "Clunk"
I just bought an 2010 XT in January. I have about 1500 miles on her.
Lately, when I start in the morning and drive....and I give her normal gassing, i hear a "clunk" type noise coming from the front. Dealership cannot find it no matter how I explain. It also did it when i was backing out at a slope.
I am very frustrated.....
Has anyone had this issue?
Does it feel like the transmission is engaging? Do you hear it, or also feel it?
Does it happen while you are already moving, or just when you start to move?
Forward and reverse?
Steering wheel straight or turned?
Sorry for all the questions, just trying to narrow it down a bit.
Some surface rust is normal, and at times the brake pads will stick to them. The clunk is what you hear when it breaks loose.
Could also be the parking brake.
At the next oil change, I would bring it up to your dealer, have them inspect the brakes and lubricate the calipers with high-temp stuff.
You said it could be the parking brake, how so?
I'd have them clean the brake parts and make sure the moving parts have heat-resistant lubricant so they continue to move freely.
I had to rebuild a rear caliper on my 93 Miata because it was sticking like that. The rebuilt caliper solved the problem.
Yours is new so it's more likely to just need lubrication.
The ABS/VDC system goes through a self-test when you first start up and drive off. It involves, among other things, a grabbing of a brake which can sound as you describe--sometimes more noticeable than others. This is completely normal.
Could this be what you are experiencing?
Bill
Others have complained about their Forester engine "knocking" after being shut off. That turned out to be the ticking of cooling heat shields.
More to come!
Did you ever discover the cause of this clunk or knock? I have a 2011 XT with 2k miles on it that has been making the same noise, typically only when the engine is cold. Any feedback you can share would be appreciated.
-B.
I think you misunderstood the dealer. The AWD system does not check itself. However, the ABS systems on all cars do check and reset themselves upon restarting and moving. And on some cars under some conditions, this reset can be heard.
My guess is that they were not able to replicate (or hear) the sound...
"Are you sure you're not just hearing the ABS self-test? That makes a bit of a clunk, I believe. I've noticed it in every Subaru I've driven."
#11 in http://legacygt.com/forums/showthread.php/clunk-after-sitting-98295.html
"I think I've come up with a way to prevent that awful ABS Self-test brake noise to occur. Right after starting the car, press the brake pedal down a few times before putting the car into gear. I've been doing that for the past few days and haven't heard that sound since!"
http://forums.audiworld.com/showthread.php?t=1368781
"ABS system self-check.
You may feel a slight shock in the brake
pedal and hear the operating sound of
ABS from the engine compartment just
after the vehicle is started. This is caused
by an automatic functional test of the ABS
system being carried out and does not
indicate any abnormal condition."
VDC is traction control that senses vehicle direction and uses brake, throttle and engine management to help maintain stability. I don't think Subaru has such a thing a self-checking VDC. Some Subarus have VDC, although not my 2008 X with the 4EAT automatic. VDC is a completely transparent feature as it is not even mentioned in the Owners Manual, much less any self-checking of it.
I'm thinking of asking the dealer to replace my car with one that doesn't make the noise. After all I'll probably drive this car for years and the prospect of hearing this noise 1000+ times a year is not a good thing.
Mariner
i guess its normal.
Enjoy your new Subaru.
bill
