Removal of Plastic engine cover
I want to remove the plastic shroud from the top of the engine on my 03 Corolla. There are two acorn nuts, and two plastic retainers. In order to avoid braking the plastic retainers, I would like to know the secret of their removal.
Members who have been around for awhile are aware that questions often get more attention when posted in relevant existing discussions than they do if placed in discussions by themselves.
Here's the link to the Corolla Maintenance & Repair discussion: http://townhall-talk.edmunds.com/WebX/.ef0a161/3624
MODERATOR /ADMINISTRATOR
Review your vehicle
2003 to 2008
1
Use a pair of pliers or a small socket wrench to remove the four nuts from the plastic engine cover.
2
Remove the rivets behind the nuts. Pry them up using a flathead screwdriver.
3
Grasp the sides of the engine cover; lift it straight up to remove it.
2008 to 2010
1
No nuts or rivets, just pull it straight up and off. It's held on by rubber push-in grommets.
The second item 1 at the bottom says "No nuts or rivets . . . ."
Which do you suppose is correct?
Yea that's funny! Toyota doesn't want you to take care of your car. On the contrare, in order to make engine access easier, the engine cover design of the newest generation of Corollas just pulls right up and off, no tools required. On the other hand, I'm sorry if I mislead you. The information I gave you was right off of a Toyota owners website. But really, was the attitude and sarcasm really necessary? I was only trying to help you.
kt6r
"to intimidate and discourage car owners from accessing the engine"
