2010 Lexus RX 350 Gas Tank.
recently I just noticed my 2010 rx350 only had a 16 Gal gas tank instead of 19.2 Gal on the vehicle. Can someone please explained the different tank installed in vehicle?
My stepfather also has a 2010, and he puts premium unleaded in his, and when I checked his gas mileage average read out on his vehicle, it was only saying 17 mpg.
Where do you put your sunglasses? Where do you put your change and loose cash when you roll through a drive-thru? Where do you connect your IPOD? All I find in the console is a mess of cords to allow me to plug in my IPOD and phones, but there is really no room for anything else meaningful. I used to put, in the console compartment of the RX300, the important things I needed....wallet, checkbook, spare keys, IPOD, and even a measure of personal protection. I find NOWHERE to place these items in the console...and if they should fit, easy access it is not. The console sits so far back, I physically have to turn to open the console. And that thing (the hole) at the base of the console...what exactly can go there? A cube box of tissues is even too tall.
I am not trying to be funny, but I test DROVE the car...who would have thought there would be no place for my things. I have found many lesser-end cars that have a better designed interior. Help! I am open for suggestions. This may sound strange, but I am so frustrated I would consider getting a different vehicle. Mistake to change or better to stick with it?
A lot of things go into fuel economy and gas mileage and a lot of factors out of our control, such as temperature, traffic, pump cut offs, etc. Also there are other factors that are under our control, how you drive (lead foot for instance), city vs highway, tire brand/class used on vehicle, tire inflation pressure, suspension issues, drag issues, brand of gasoline used, if the vehicle is loaded down, etc.
Just for everyone's questions, the Lexus website says the RX350 comes with a 19.2 gallon gas tank and when I was shopping last year that's what the sales people told me so that is the size your tank should be. If it is not, then there is a big boo boo on your RX! Also, the fuel recommendation is premium gas so that is what should be put in it (91 octane or higher). I've come to find over the years, that when it comes to gasoline whether is says requires or recommends premium I put premium in. Not only did it keep knocking/pinging and engine idle issues at bay but it gives you maximum performance. I would not be putting regular in a RX if I were you. If you wanted to do that then you should have gotten a Toyota.
Sometimes you can get away with mid-grade (plus) instead of premium but around where I live, the difference in price between mid-grade and premium is 10 cents so I don't mind spending the extra $1.50 a week putting in premium.
Just remember, you only had the RX 4 years under warranty, God knows the long term affect of using regular (6+ years) and once your out of warranty. If something was to ever happen to your exhaust system or anything else related to it out of warranty, it doesn't mean jack squat what that service advisor said to you and you'll be blamed for putting regular in
If the owner's manual says premium recommended or required there is a reason for it. You might be able to get away with mid-grade but not with regular. The car is designed for premium.
This is just my opinion but I can't understand why you'd spend the money on a expensive luxury vehicle like the RX and then not fill it up with the recommended premium gas. Your not really saving that much money a year by putting the regular in vs the premium just to save a few bucks on a expensive vehicle for everything else (oil, tires, etc).
Seriously though, it's not just the service advisor that has suggested this. I've also talked with other auto mechanics regarding using regular unleaded gas vs. premium on vehicles that the manual says otherwise. They've said the same thing.
So, no, I'm not convinced yet about this.
Some guys on a Nissan forum I belong have gotten away with mid-grade with no problems or reduction in mpg but no one is putting in regular. So some vehicles the grade of gas makes a big difference.
IMMHO required means REQUIRED.
Recommended means you have the OPTION.
For about the past 10 years now "high" compression engines have had the ability to run on regular fuel with no detriment, short or long term. First and foremost the compression ratio is pretty much meaningless except when the cylinder is getting a full A/F mixture charge.
So the only times the fuel grade is important is with/at WOT, or close to WOT. The second is engine lugging, operating the engine in a to low gear range for conditions.
With the advent of non-resonant, wide band, knock/ping sensors the engine control ECU simply uses the EFI PWM, duty-cycle, to slightly enrich the air/fuel mixture thereby alleviating any tendancy to knock/ping. In the case of lugging the ECU commands a transmission downshift.
Slightly lower maximum HP/torque and FE, that's all.
I can tell you from the experience with my 3.5L VQ engine that a high grade displacement engine, such as that one, would have a severe detriment to it if used lower then mid-grade gas so for some engines it still makes a difference. I wouldn't have thought it till I saw and felt how bad the car was struggling to go down the road with regular in it.
25000/22 mpg= 1136 gallons per year x 5 years = 5681 gallons
5681 gallons times .35 gallon= $1988 savings. That's worth thinking about especially since there is no improvement on gas mileage or decrease performance. Consumer reports advises the difference between high octane gas "recommend vs required" such as a turbo engine. Just saying if there is no clear advantage why spend the money?
As far as premium gas for 2010 RX350, with some of the comments above, I will start using regular unleaded. I find it annoying that 2010 is to use premium and later years use regular unleaded. In the old days, premium gas was $0.15 more. These days they charge up to $0.50 more.
I have a 2009 Mercedes E350 that requires premium and I will always use premium in that car. With Mercedes, BMW, Audi, they all require premium. They don't go back and forth between the years.
It is strange that the sane engine under Toyota brand uses regular and under Lexus, it should use premium.
