Are you shopping for a new vehicle and having trouble finding one, or have you been waiting a long time for a factory order? A reporter would like to speak with you; please reach out to [email protected] by Tues. 5/11 for more details.
EATC repair. (auto climate control) 06 Grand Marquis LS
59william59william Member Posts: 1
edited July 2014 in Mercury
It's my understanding that there are shops repairing these controls. Does anyone out there know which part of the control is defective. I've ohmed the solenoids that control the vacuum and they are all ok. I also tested as many of the resistors on the boards that I could. The solenoids were very hot when I disassembled the unit.
  • jagwiredjagwired Member Posts: 2
    william, had my atc on my 03 grand marquis rebuilt for about $100 and with life time guarantee, less than half of a used one that didn't work!! Auto Truck Electronics, 1-866-983-6688 good luck...Dan
    Can the grill on a 03 GM be removed from the front?
  • snorkelbobbysnorkelbobby Member Posts: 19
    most of these where it blows out the defrost duct (fail safe mode) is just the vacuum harness not held tight to the control head. Use 2 10" tie straps to hold the vacuum harness tight. Remove the 2 torx screws and wrap the tie straps around the bottom piece and on either side of the black vacuum hose. Pull tight and test.
    The vacuum harness is available from Ford for $22. The prefix of the part number is F5VY-, I can remember the rest. Still needs the tie strap though.
