1992 Legacy runs great then stalls...
My Legacy runs great but it has been stalling then I have to pull over ( not always easy to do safely here in NW Montana) and wait. If I try to start it too soon, it will start but stall again. It is getting worse.
When I bought the car, the guy said he was told by a mechanic it was the front o2 sensor, but a subaru guy tells me, if your dummy lights aren't on, don't spend the money. It ran great for me for months before it started doing it.
SO, what are your thoughts. It's my only vehicle that was running now I can't trust it. I got about 15 miles before it started doing it in the morning but only about 1 mile that afternoon to go home. I need ANY thoughts or experiences even close to this because I am desperate. Thank you.
I would check, in order:
spark plugs
fuel filter
spark plug wires
ignition coil
fuel pump
I'll price an ignition coil also..can't hurt to replace it. I suppose I will go ahead and do wires and plugs then I know for myself. Thank you for suggestions so far
Ignition coil on mine was about $80.
I thought to myself "what other elements are part of the fuel delivery system?" I see Throttle position sensor and injectors. The sensor is $329 eeek. There is a place I can take the injectors to to have them cleaned for $15 a piece. I bought wires and plugs so I'll put those in hopefully tomorrow. But I think I am on to something. Anyone else with suggestions?
I haven't been thinking ignition because it always starts. Even after the stall, it will start for a few seconds then die unless I allow it to rest. Fuel filter is new. :sick:
Took the vacuum hose off the Fuel Pressure Regulator and plugged it and it runs better. Is that odd? It is to me.
I haven't really taken it out onto the road until tomorrow morning on my way to work. I gave it throttle plenty of times and it hasn't stalled but as I mentioned it is very unpredictable. Time is drawing near for my road trip and I don't know what to think. :confuse:
