Toyota Sequoia Cruise Control
treedriver
Member Posts: 5
in Toyota
I have a 2010 Sequoia Platinum with 2 problems that I was wondering if anybody else has had.
#1 The cruise control will not stay on if the windshield wipers are on. After about 6 swipes across the windshield with the wipers, the cruise turns off.
#2 the tail pipe has melted the bumper after just 5000 miles. They should have extended the tail pipe past the bumper to help the heat escape but they didn't.
After buying a car valued at $61300.00 I think this is BS
Other than the items listed above I do love the car, but it is thirsty and it has a small gas tank.
What is interesting is that when the system crash occurred, the Bluetooth quit working temporarily. It erased all my contacts and speed dials. I corrected it and has not happened again.
Expecting your prompt answer
Luis
Actually, it is possible to bypass the laser cruise permanently. I did this with my 08 Sequoia Platinum. I was getting the same error in the dash, brought it to the dealer who said it needed a new laser. So i did some research and disabled it.
Here is what you need to do: First unplug the distance control ecu unde the dash (behind the body control ecu). Next I initiallized the cruise control with the engine ecu (turn key on, step on brake, push up on cruise switch 3 times quickly). This sets a flag in the engine ecu that the laser cruise isnt there. If that doesnt set the flag, you can check with a Techstream and also initialize it through that tool. You can pick up a cheap model Techstream on ebay for about $40 and it is really helpful. At this point if you test the vehicle it still gives the dash error. So next unplug the laser module in the bumper. This will do a couple things, 1 it will now make the cruise act differently with only the light on the dash, and will also cause the stability control and abs mil lights to come on. This is because the stability control ecu is still expecting the distance control ecu to be there. The final step is to clear the learned memory on the stability control ecu and reload the data from the engine ecu (easy steps with the service manual) and your done. The cruise now works like a standard cruise with no more problems! Hope this helps someone!
