2001 Cherokee code problems- need help please
I have a 2001 Jeep Cherokee
A few months ago my engine light came on, so I had a friend with a shop plug it in and it came up with numerous codes
Misfires several cylinders
O2 sensors bad
cold start sensor
electric fan sensor
It runs perfect in cooler weather, but once it gets above 80 degrees it acts like the choke is stuck when you start it up after its been ran for a while, takes 20-30 seconds of light gas pedal to clear it out, then it runs fine
Also when idling for extended periods it will overheat because the electric fan for the radiator doesn't turn on. I checked the fan and it works.
Also the A/C no longer works, the clutch does not engage, and the coolant level is ok.
My passenger windows only work on my consule and the front speakers are no longer working.
Do I have a computer problem? Or just a bunch of things going wrong about the same time?
THANKS !!
O2 sensors bad
cold start sensor
electric fan sensor
THANKS !!
