2004 Honda Pilot transmission is junk!
I just recently (in November) purchased a 2004 Honda Pilot. The transmission starting causing shifting problems. The first time it was like I slammed the brakes on but thankfully I was just going up our drive way and not driving fast. I started driving again and it kept messing up. Then the green light started flashing on the D when I was driving and parked. I took it in and they plugged it into the computer and it was a transmission code. There was also a 2-3 shift malfunction. They said my transmission needed replaced. I looked up recalls and my car had a recall for the transmission and it was """fixed""" in May 2006. However, they did not change the transmission, just installed an oil jet kit to keep it lubricated! Apparently that did not help especially if there are chips of metal in the fluid! Everyone I talk to just tells me my car, being at 104,000 miles, is out of warrenty and they have to draw the line somewhere! No crap people! But if you would have fixed the darn thing properly when it had a recall it would not need replaced already! Honda has been horrible through this and refuse to help me. I am a single mother of 3 children and I can not afford a new tansmission at $4,000 especially when it is their screw up and they should have to FIX their recall! I am so angry and will NEVER buy another honda as long as I live and I will tell anyone I know about their horrible transmissions and their bad customer service. They are just trying to cover their butts on this one. It is time they start helping their customers rather than basically saying "its your problem now". From what I see this is an ongoing problem with Honda and I think something needs to be done!
http://ww2.justanswer.com/uploads/thebesthonda/2010-02-04_181956_B06-003.pdf
Two weeks later, I got the blinking "D" indicator and paid $170 to get the 4th gear pressure switch (a known defective part prone to failure) replaced.
Two weeks after that, I got the check engine light and dreaded PO740 "TC clutch failure" code. Exactly the same issue as yours -- torque converter failing, will eventually send little bits of material into the gears/clutches and destroy the transmission.
The problem(s) are that Honda (a) will not rebuild the transmission at the dealer. They just charge you $2957 for a remanufactured one and keep your transmission case (which is a $1500 part in and of itself).
If you're an original owner, Honda corporate has the authority to offer 50% off on parts and labor. They tend to do this only if you purchased the vehicle from one of their dealers (I did not) or the vehicle has a history of lots of repairs (mine has a clean history, which is why I bought it).
If you read the P30 recall carefully, there were TWO remedies -- the oil jet you got (Band-Aid to a design flaw) and replacement of the tranny. Gee, I wonder how many folks got the $4000 repair (heart surgery) and how many got the oil jet (Band-Aid).
BTW, I asked my service manager about the oil jet -- the techs hate them because the pressure is so high that it makes reconnecting them and filling a rebuilt tranny much more difficult. He seemed to have a low opinion of the effectiveness of that part.
I have gone back and forth with Honda corporate (was also told I would get no relief, among other outrageous things) and grovelling with my dealer and DPSM (District Parts and Service Manager). Of course, no last name or contact info is given to the almighty Eric of District J. It's all me having to call and re-explain my issue.
In the end-all be-all, I'll probably be out $3200 plus about $300 in rental car bills plus the initial $170 sensor repair which turned out to be unneccessary. Not a good way to introduce one to the world of owning Hondas! :sick:
My 2003 pilot had the same problem and it was exactly to your story! My transmision failed at100,000 miles and there was a recall that honda claimed they fixed???????????? Honda wanted to charge me 5,000 to fix the trany I cant afford this money! Do you know of anything we can do to hold honda accountable? I am willing to try anything? I am proud to say i will never buy a honda again!
Chris
http://townhall-talk.edmunds.com/direct/view/.f1155f7/219!keywords=#MSG219
http://www.piloteers.org/forums/14-problems/26886-sporadic-vibration-low-speeds-- 2.html
http://www.autoobserver.com/2010/03/honda-odyssey-owners-report-transmission-tro- ubles-inconsistent-response-from-maker.html
Most people are in disbelief (like myself) that this could be a defect with the Pilot (and MDX and Odyssey) transmissions. I was just recommending the Pilot to a friend over the past weekend and claimed that it was our best purchase ever (vehicle or otherwise). Our only recourse might be to take whatever Honda will do (cover 50% in my case), and submit a complaint as suggested in this post:
kpsmith999, "Honda Pilot Transmission Problems" #177, 22 Jul 2010 5:55 pm#MSG176
Please take the time to do so, it took me about 10 min and you need your VIN information.
Anyone have thoughts on getting Honda to pay more for it? I wouldn't mind paying for labor, but they need to at least throw in the tranny instead of covering all their costs and just removing their 50% markup on parts and labor...
I'm preparing to write to Honda- anyone that's had success can you let me know what did the trick? I'd love the entire bill picked up but I think I may be too optimistic.
