2001 Legacy/Outback Shaking at Highway Speeds: Help!
Help! I have a 2001 Subaru Outback. When I drive at highway speeds, my car will begin to shake. I can hear the engine working harder and it just rides rough in general. It comes on slowly and goes away slowly on its own. It seems to do this more frequently when I use regular as opposed to mid grade gas.
In the last year, I have had my head gaskets redone, a new driveshaft put in, new spark plugs and wires, and a new knock sensor. I do not have a lot of money to spend on getting this diagnosed or fixed, so if anyone knows anything that can help me, I would greatly appreciate the information. Thanks.
Next thing I was thinking was the ignition coil, but unburned fuel should trigger a CEL.
Taking a WAG by your description, I suspect the driveshaft is out of balance; probably something to do with the center bearing or the bushing surrounding it. Did the problem happen before your had your driveshaft replaced, or only since?
I had something similar happen on a '96 Outback, but it only manifested itself in high-torque situations, such as when accelerating hard, while turning, coming from a stop (like taking a right turn from a stop light). The car would shake a little, plus I would hear a LOUD thumping from under the car. I replaced the front half of the driveshaft and all was well. The rubber bushing that surrounds the center bearing had begun to fail.
In response to the first response: no check engine light on. I suppose it is possible that the actual bulb for the check engine light burned out, but doubtful.
If it's burned out I'd get a code reader and pull the codes.
Automatic or manual?
When it suddenly begins happening, try shifting into neutral (or if manual, depress the clutch). Note - only do this when you are alone on the road - not in traffic! If it is related to balance of a half shaft or center drive shaft, it should continue to shake even as the engine rpm dies off to idle. If it stops abruptly, it is more likely an engine/tranny problem.
I actually do have an appointment for it in about a week for someone to look at it.
I didn't see this as a shaft balance issue as it doesn't happen consistently at around the same speed and conditions. A permanently out of balance component (tire with a broken belt, bent rim, shaft missing a weight) usually gives a pretty repeatable performance. If it is occuring and you depress the clutch, one would expect the shake to continue. But again, you should be able to induce it easily by just hitting the right speed.
If it was an engine misfire (injector problem, ignition failure), you would expect to eventually get a CEL. I know that even with an automatic, it is possible to load the engine down on a hill and make it 'lug' a bit prior to getting a downshift. That produces a bit of shake, but it disappears as soon as the downshift occurs. It is a form of misfire, but not enough to throw a code. But depressing the clutch at speed would make that instantly go away as the load drops and the RPM drops.
One thought. Yours is an '01. Mine car was a very early '02 that came thru with '01 brakes. I hate the brakes on this car. They are very prone to 'warpage' (actually an uneven material transfer to the disk that results in thickness variation). I can scrub this off and smooth out the braking, but under some conditions it comes back. On some long, high speed drives I've had 'transfer' occur for unknown reasons. Minor contact friction building up heat??? Net is that sometimes when I do get on the brakes, the front end shakes, and I can sometimes feel it even when not touching the pedal. Slow down or stop for a while, and it goes away. Inspection doesn't indicate a non-retracting caliper, and brake wear appears to be quite normal. I've got around 35k on this set of pads, and they still look OK. But it does sound a little like what you describe.
You might want to have your mechanic do a thorough check of the calipers (sliders and piston retraction), look for uneven wear, etc.
Long shot, but without driving it, it is hard to diagnose.
