Nissan Murano Bad Head Gaskets
I have a 2009 Morano SL with the new at that time aluminum 6cyl engine. I have just been told that my headgaskets are shot. Since I am 6k miles over the 60,000 mile warranty Nissans says too bad. What kind of company does not warrant a non moving part on a new engine for more then 2 years? Beware!!!!!!
The redesigned part became available as a replacement part in February 2010 as an FYI, but I do not know when Nissan began installing the new design head gaskets in their cars/SUVs off the line; obviously before February 2010.
It is important to check for head gasket leaks and tail pipe emissions problems so that the problem can be caught early.
The powertrain warranty is 5yrs/60k miles (WHICH EVER COMES FIRST!!)
60K miles is definitely an unusually high amount of miles to have on a vehicle in just 2 years so you reached the 60k miles first before the 5 years.
You could try calling NCA's and try pleading your case to them that your only a little bit over the warranty miles and see if they could at least meet you half way but I seriously doubt it.
I looked at this issue closely, and came to the conclusion that heat stress either deformed the aluminum associated engine areas causing the head gasket to lose functionality and place it under unusual physical stress or the head gasket itself underwent heat deformation. There are known instances of engine and coolant additives clogging the head gasket channels as well.
Although the problem is known, particularly in the 2009 Muranos, it really is a small percentage overall, and less frequent than transfer case/seal problems in the AWD versions of the Murano. Together , these two issues comprise the vast majority of serious problems that affect Muranos in general. Remaining issues tend to cluster around electronics problems in the LE series of Muranos.
Took the 2010 Murano in today for the service due at ~64K. Was told that the head gaskets appeared to be leaking. Since I bought the extended warrentee I will pay nothing except for 3 to 4 days without the car - do get a free rental though. Nice to win on this kind of a thing for once. When this sort of thing starts, for unexplainable reasons (usually), nothing ever seems quite the same and the problem rate seems to increase - this is irregardless of make/model. Needless to say this thread does not make me fell very good. I am going to check the warrentee and if I can get another 2 years out of the vehicle I'll do that. Our mileage will go down drastically by the end of this this year so I may be able to do that. We bought Nissan at the recommendation of the mechanic we use once vehicles go out of warrentee, and the fact that one time years back I had a Datsun PU for 11 years with few problems. Didn't know about the Renault link - sounds reasonable...
