Blake
ABS used only to be available on the D35.
I have no idea why ABS isn't available on the Rubicon. Option availability is a closely held DC secret.
Yes, it's pretty standard on vehicles these days. Personally I find it beneficial in most off (and on) road situations, but I'm in a minority.................and yes, you can easily disable it by pulling a fuse or removing a relay.
Of course I doubt a 350 has that nice torque curve, and it definetly don't have as much power as that 5.0 stroker, good gosh thats to stout for a Wrangler or a Cherokee, you would have to replace the rear end, and the transmission.
had a blast!
i put myself in the middle of the group so I'd have plenty of help, my nicole was the smallest in the pack, but she did alright, everyone else had quite a few modifications, lifts, tires, lockers etc.
I wasn't the first to get stuck and I made it through where carl got stuck (made me feel good to pull him out)
yeah, i had plenty of help, we'd come to something i wasn't sure about, or couldn't go forward, the usual comment was back up ,, hit it harder!
did get a chance to use the winch, and tomorrow i get a chance to stretch the cable out and respool the birdsnest thats in there now. the trail was uphill and rutted, she just got to a place that a front or back tire was just hitting square on and she wouldn't jump up on it. we winched her up there, and the jeep behind me did the same thing.
then carl got a chance to pull me back when i high centered, off a pile of dirt where O R had made a creek crossing. some of the girls I've dated aren't height / weight appropriate, well Nicole isn't exactly height / length appropriate. hopefully thats going to be corrected soon!! (why don't they make lift kits for women?, apologies to any women on the list, i'm know there are plenty of guys needing lift kits too!)
sort of glad she got stuck there, 3 of us decided to skip the creek crossing and go around. 2 jeeps found a hill that was more than they wanted,, way more than Nicole would have wanted.
No Dents / No Scratches / Nothing Broke
Ready to go back!!
jeff
I'll post pics next week, i had my film camera with me.
switched over to mobil 1, nearly forgot to put the oil plug back in, and almost dumped all 6 quarts right through the engine into the dirty oil pan. would have been an expensive mistake!
jeff
- gather new oil and filter (to make sure I have what I need)
- put drain pan under oil pan
- remove drain plug
- put drain plug in top of new filter
- remove old oil filter, place small drip pan under filter location
- get grease guns and hit all zerks with syn or poly grease depending on application
- log mileage and date on back of oil filter box top
- write up new oil change sticker (many auto parts stores give these out for free now)
- top off washer fluid
- visually check radiator overflow tank and brake fluid, diffs and tranny through check holes
- check air pressure
- replace drain plug
- lube up gasket on new filter
- wipe filter seating surface
- hand tighten new filter
- recheck drain plug :-)
- add new oil
- start engine until oil pressure shows, run 30 sec.
- shut off engine and fill containers with old oil
- put away tools
- check oil level
- grab an adult beverage
Sounds a lot more complex than it seems when doing it, but after a hundred or so oil changes, it's routine.
I will be the first to admit that having a garage has made auto repair/maint. much nicer in extreme temps or inclimate weather.
-twylie
It's good to hear from a fellow Marine. I just returned from Twenty-Nine stumps where we were doing some live fore training. I couldn't help but think how much fun it would be to have a Wrangler out there. My command frowns on our taking the HMMWV's out for some wheeling fun(go figure).
The biggest reason I'm considering the Unlimited is the extra cargo capacity. After several years with the Miata I think I would enjoy being able to transport something larger than a small lunch box for a change.
Semper Fi,
Clay
Sounds like "another one bites the dust." You're hooked, ain't ya?
So, when are you coming down here to Turkey Bay?
Did you get pics today????
Tom
Have you hugged your Jeep today?
If the weather cooperates we're talking about taking GiGi out for some real wheeling. I'm still nervous about taking out our not-yet-2 months old daily driver!
My issue is that I would like to be able to play MP3's or burned CD's and my radio isn't having it. I thought that since my computer is now newer than the player, the burner is better, but alas, that was not the case. I'm not much of a car audiophile, but it looks like all of the radios are too small to fit where the jeep stock radio fits. Also, I'd like to get something that has the ability to withstand the elements like the stock radio (not that I intentionally leave the top down, but SC weather changes in a heartbeat), any ideas?
In an ideal world, I'd like to get an XM/Sirius/CD/MP3 capable system.
des'
Can't really let that go without comment, pricing first.
Jegs will supply a Goodwrench crate motor with those specs for $1400 as a bare long block. Adding a carb, manifold and distributor, takes it to over $2000.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=146- - 671&prmenbr=361
However, we don't want a carb, we need fuel injection......way more expensive. Plus of course, a starter, alternator, exhaust manifolds etc., etc.
Next, transmission. Jegs cheapest own brand TF 350 comes at $650 without torque converter, so add $100-$250.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=452- - 45&prmenbr=361
Assuming that you've managed to bolt this setup to your NP231 transfer case, it's not going to be in anything like the same position, so new propeller shafts are required.
While all this can, and has been done, it's no simple plug and play bolt in. How will you marry the requirements of the GM's FI to the Jeep's computer and wiring. Custom engine and transmission mounts will required, as will an exhaust system. Better budget for a new custom radiator as well.
As I said, it can and has been done, but please, please tell me, who will do a professional complete custom installation of these various parts for $500???????????
Think of the obstacles that I can negotiate with that much flex. I doubt if I EVER go any bigger.
Tom
It's funny that Tom brought up the fact that you don't necessarily need a big lift. Today we had GiGi out on a 4WD trail. It had moderate grades and sheer drop-offs. It didn't have any off-camper sections, but I was thinking about such situations as we climbed up (I had never been on this particular trail). I could see where going with a big lift could raise the center of gravity to a point where you would have a much higher roll-over risk in such situations.
Speaking of which, the Unlimited certainly felt more stable and sure on this trail than I had expected. I'll probably use 4-low more with the automatic - it sure came in handy when I started down the grade (the route isn't particularly maintained - it goes to an abandoned fire lookout tower. Incredible views and lots of fun!).
The GPS earned its keep today! I have a new guide to trails and we were trying a new trail in an area that we've never explored before. The guide had the grid coordinates indicated for a variety of points along the trail, including the starting point. We were coming from a different direction than the book did, and the book said that the road wasn't marked. We got to the grid coordinates for the start, but it looked like a farm track along someone's field. I couldn't believe that was the "road" we were supposed to be on, but it was. If it hadn't been for the GPS, I wouldn't have tried it - just figured the guide book was wrong and gone home. Next time I'll believe this particular guide, and my GPS. This is opening up so many new places to explore!
Unless you have an actual need to be able to tackle larger obstacles, it will just mean that you have to go and find some harder trails to have as much satisfaction as you do now.
Some people don't seem to realize that it's using the vehicle to its limit that improves the driver's skill and gives the most satisfaction.
I have an older Alpine head unit in my wrangler with aftermarket speakers and 2 amps. Works fine for me. I plan to add Alpine's CDA9820XM unit soon and put the antenna up on the roll bar (under the fabric top I have. Check the stereo websites about burned CD/MP3 capability. The Alpine was a snap to install for the dealer, but if I had to do it again (as in a whole system install), I'd do it myself - the Jeep is THAT easy to work with.
-Paul
I am in NO WISE qualified to discuss HOW the different types of differentials work, but I can tell you what they do.
All differentials perform the job of converting the rotation of the drive shaft into the rotation of the axle shafts, which are attached to the wheels. This is what makes the vehicle move.
We're gonna need Mac here to explain why with an open differential the power goes to the wheel that has no traction. All you have to have is one tire without traction and you "ain't goin' anywhere." There is no power delivered where it will do any good, i.e., to the side with traction. The tire without traction will spin, and the tire on the opposite side will just sit there doing nothing.
This is where a limited slip differential will help. As long as both tires have at least a LITTLE traction, the vehicle will move. Somehow, the limited slip differential will deliver power to the side that has the better traction. Limited slips are really nice, as long as you can keep both tires on the ground. They have much better highway manners than do full lockers.
Some limited slips work with clutch packs, and this means that eventually they will need replacement. The gear oil in these differentials usually requires some friction modifier additive. DC puts this type of differential in some Wranglers, and it is called the "TracLoc" option.
Finally, there is the good old "locker." A full locker will make both tires pull, even when one side has zero traction. Even if the tire on one side is completely off the ground, the other tire will pull. Lockers are great on the trail, but they can have some undesirable side effects on pavement.
When you make a corner, the outside tire has to turn faster than the inside tire, since it travels a longer path in the same amount of time compared to the inside tire. This means that both sides cannot be locked together during corners, and the locker has to "ratchet" to let the teeth slip past each other.
The reason you can corner more smoothly off road with a locker is because there can be some slippage of the tires on the dirt when the tires are trying to turn a slightly different speeds, when the locker has not released quite soon enough.
The degree to which a locker is able to release and re-engage smoothly determines how street-friendly it will be.
I have had a Detriot Soft Locker in the rear differential on Thelma Jane for over two years now, and I LOVE it! It makes a huge difference off road, and its street manners are not bad at all. I just had to adjust my driving style slightly: mainly, just not getting back on the gas quite as soon after cornering. You just have to be aware that you need to keep from accelerating while in the middle of a corner.
I recently put a Lock Right locker in Thelma Jane's front differential, and it was a good mod for me. I really like being locked front and rear.
A front locker does NOTHING when you are in two wheel drive, so street manners are really not much of a factor for a front locker. The front axle shafts, front differential gears, and front drive shaft all turn on a TJ, even in two wheel drive, but because there is no torque being applied, the locker is not engaged. You can hear some distinct clicking in corners with the front Lock Right, but that is not a "biggie" for me.
Selectable lockers would be great, if a guy could afford them. These can be turned off for the pavement and turned on for the trails. Rubicons come with standard front and rear selectable lockers!
Mac, as always, feel free to jump in here to clarify, to correct, or to add to what I have said.
Tom
P.S.
This little trick might come in REAL handy sometime, if you don't have a locker.
You can "fool" your differential into thinking that both tires have traction by applying some brake, while at the same time attempting to drive out of a "stuck" situation. The resistance to turning caused by a little brake pressure will be interpreted by the differential as tire traction.
Tom
is limit slip or a locker better when Nicole is perched on top of a pile of dirt with no wheels touching the ground??
jeff
-Paul
I bought the new bit and bought the size required by the tap I was thinking I may need to use after I mangled the job. The kryptonite bit cut through the bolt like it was butter. Well, frozen butter at least. With about a minute of effort the head of the bolt was off. I then switched to a smaller diameter bit and drilled all the way through the bolt. Then I used an E-Z out to remove the shaft and it came out quite easily. I should mention that this was the bolt to which heat had been previously applied, thanks Mac.
Unfortunately, the other two bolts have broken off E-Z outs in them and even the Kryptonite bits won't bite into that.
My next trick is going to be to take it somewhere for professional help before I make it any worse. I've used up all my patience and am ready to spend some money.
I'm thinking of going to a body shop for help. Does that make sense or is there a better type of shop I should try?
Dave
I was a little hesistant about XM, but if the unit comes XM capable and all you need is the XM tuner, it should be a snap to remove the radio faceplate and the XM tuner, right? Also, how well does the antenna work through the fabric of the top?
des'
It helps to think of a regular open differential as an 'unlimited slip diff', which allows the wheels to rotate at different speeds as needed.
A 'limited slip diff' allows independent rotation of the wheels, but limits the amount of rotation.
A 'locker' or 'automatic locking diff' keeps the wheels locked together until it senses a speed differential is required, when it will unlock the coupling of the wheels.
A 'manual locker' performs the same function as an open diff, but enables the driver to lock the wheels together as required.
A further variation is a permanently locked rear end which allows no independent rotation of the wheels. This is known as a 'spool' or 'lincoln locker' (as in the brand name of a welder!). It should only be used off road and never in a front axle.
Generally, limited slip types use clutch plates which can wear, but there are types which use gears.
Generally, automatic lockers use dog gears to lock together, but there are some that use clutch plates.
Manual lockers can be operated either by vacuum, solenoid, compressed air, cable or lever.
But if you go with the Alpine unit with the XM tuner already installed into it, all you would have to add is the antenna.
I've heard mixed reviews about the antenna through a soft top. Some say it works great, some say it won't. I'd try it on the roll bar first, and if it didn't work, move it somewhere else. This xm-integrated unit makes it no different than installing a regular head unit (with the exception of the extra antenna for XM).
-Paul
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
The reason I decided not to go with a radio that requires a separate XM tuner (XM ready radio) is because I couldn't figure out a good place to put the tuner. I've seen photos of people that put the tuner on the back seat, but my back seat is rarely in my Sport (though I've left it in the Unlimited - I don't feel so much of a need to have the extra cargo room). Paul has talked about putting it under the driver's seat, which makes sense, but I'd worry about it there. That's why I chose the Alpine radio that includes the tuner - I think they are about the only one that makes one at the moment.
The tuner is permanently mounted somewhere and can be hidden away - no need to remove it with the radio faceplate. I never worried too much about having the Roady in plain sight - since it is a subscription thing, all I would have to do is call XM if it were stolen and they would deactivate it.
So, any demand for an old, fat guy that bought a new Wrangler four years ago?
Tom
I have the vehicle I have been looking for all of my life. The girl of my dreams.
It was four years ago today that I signed the dotted line on the deal. The order went in the next day to the factory.
Tom
jeff
des'
So, when are you going to come down here for some wheelin'?????????!!!! I want to come up there sometime and check our RORP. Learn that place real well, so you can serve as trail guide when I come up.
Tom
My 98 Jeep Wrangler 4.0L has developed a hesitation recently. After it is started, about 1-2 minutes in, it begins to idle very roughly. This lasts about 2 minutes, then its fine. During the rough idle, there is virtually no power as it struggles to keep from stalling. It seems to not be related to outside temp. In fact, if I turn it off, and start it up 5 minutes later the same thing happens. Any ideas?
I am not a mechanic, however given instructions I can usually accomplish the task.
Mac should have a better idea of what is going on.
Tom - congrats on your anniversary! In 2 more days GiGi will be 2 months old, and I noticed today that we've got over 8800 miles on it. That will work out to 50,000 miles a year, not the 40,000 we used to put on the Tacoma. Definitely an indication of how much more we like the Unlimited!
Your problem could be one of several things, but getting any fault codes will help narrow it down.
Which model did you buy?
-Paul
Mtngal, weren't you asking about raising your seat height? I added the 1 inch spacers from Buchannan over the weekend and wow, what a difference. My visibility is much better toward the front of the vehicle now. For now I'm only doing the driver's side. I get enough complaints from passengers about how difficult it is to get in.
I think next up for me is going to be new bumpers. Don't know when I'll get around to that.
Regarding XM radio, I went with the Roady2 because in Memphis if you have an aftermarket radio in your convertible it is begging to be stolen. A friend of mine had his Wrangler broken into. They stole the aftermarket radio, even though the face was detached. They then broke into the center console--where he had hid the faceplate. Kind of funny, actually.
-Paul
-Paul
but within the month she's going to have a growth spurt,,, and will be getting bigger shoes too.
talked with john at toumbs garage today, and told him to get me scheduled! i wish i had been there yesterday, he said he just finished another unlimited, 3.5 inch RE SL with 32 inch tires, said everything went great, no vibes, no gearing problems, lots of flex. i think i'm going to get 33x10.5x15 BFG ATs,,, (i'm getting 1" BL too) Nicole is going to be spending much more HWY time than trail time, so I'm planning to keep my eyes open and maybe get a set of used MTs with rims ( 12.5?? ) to throw on it when I know I'm going to hit the trails.
Yes, Tom,, one time out and I'm hooked.
The Roady is a very good option - I used a Roady all summer in the Taco and loved it. We'll see how long the aftermarket radio lasts - it isn't a problem at home, just if I go somewhere else.
What you said about the trails is supposedly the biggest reason to add them.
I wish makers still did the slide out head units like they did 10 years ago.
-Paul
You most definitely want mud tires for your wheelin'. Whether at RORP or most anywhere else in the Midwest, you are going to encounter mud. If you are like me, you will avoid mud when you can, since it does the Jeep no good in the long run, but you will have no choice but to go through some mud once in a while. Mud tires are not just better in mud, but also in loose soil, which is VERY common in Midwest wheelin'.
You keep avoiding my question! WHEN ARE YA GONNA COME WHEEL WITH ME???? And, I seem to remember some "Mr. Keats" that was supposed to come to Turkey Bay to do some wheelin' with me too????
You guys will learn that having someone who is intimately familiar with the area to guide your group makes the wheelin' a hundred times better. I'm offering you guys a chance to see the very best of Turkey Bay. Why don't you take me up on my offer?
Tom
