Rhythmic clunking noise from right rear wheel/exle
I have a 2003 OBW that has developed a clunk, clunk, clunk noise form the right rear wheel area. Seems like it might be an axle (bad cv joint). the noise increases on the highway forcing me to take a secondary road. I am not quite sure how to diagnose a bad rear cv joint as all the boots are untorn. the frequency of the noise seems to match wheel rotation but it isn't a clack, clack , clack like I am used to in a front axle situation. If I have someone drive the car slowly I can bit my hand on the fender and run alongside the car and I can "feel" the clunk like some one is hitting the car with a hammer. I can find nothing loose. Any thoughts and help would be appreciated. Thanks
bearing-usually growls not clunks but I am not sure if it could make a sharp clunking noise.
CV joints- usually gets louder when you turn but this is a rear axle so no turning to test. My boots seem fine but joints can still just wear out. Car has 180k miles.
Differential- I know nothing but from what I have read this could cause a clunking noise.
Brake caliper- a quick inspection turns up nothing alarming.
If this is the drive axle how difficult is a rear axle on a OBW to replace. I have done my Honda and VW for years so I know the basics just not the tricks on a Subaru.
Thanks again for your thoughts. Jon
We had a Mazda 626 that had a bearing go out and I described the sound as "chunk chunk chunk", also speed-dependent.
