Increase tires
My stock tires are 215/70R15 and i want to change to 215/60R16. Based on what i've read there will be a 0.6% change in the speedo. Is there anything else i would have to worry about. A mechanic told me that the transmission would have some problems. I can't seem to find anything online related to this.
If you are aware, and that is not a deal breaker, then you'll want to use 225/60R16. Those have the same load carrying capacity as the 215/70R15's and the diameter is even closer.
stampsource
1) Which engine does your van have?
2) Where'd you get the 16" wheels?
