Land Rover LR2 new tires and TPMS?
I have about 37K miles on my 2008 LR2 and will be replacing the tires shortly. I am considering replacing the OEM Conti's with a new tire from Toyo called Versado CUV. Anyway, my question involves the TPMS sensors on the wheels.
What have other LR2 owners done with the TPMS when replacing tires? The three basic options are 1) leave them alone, 2) use the TPMS service kit to replace just the assembly hardware ... rubber grommet, retaining nut, etc., or 3) replace the sensors.
I have also heard that these TPMS sensors are fragile and easy to break when removing the tires. In this case, who pays for a new TPMS sensor ... the shop or the owner?
I did encounter a shop that made it sound like the TPMS sensor was faulty if they broke it, and they would charge me for the replacement. I will not be doing business with them. So it's worthwhile to ask this question when getting a quote to qualify the tire dealer before doing business with them.
I decided to go with the OEM Conti's as my replacement tire. One of the tire dealers I spoke with, who sells all tire brands, convinced me that OEM tires are generally the best match for your car unless you have some particular driving conditions that are better suited to a special purpose tire.
Regarding TPMS service, the advice I got is to leave them alone, at least for the first tire change. The rubber grommet seals and hardware should be fine on a car that is only three years old, so no need to apply the service packs (even though the owners manual tells you to). The service pack should be applied on the second tire replacement.
And no need to replace the TPMS sensors themselves as their batteries can last up to ten years.
