Dodge Durango Lease Questions
13»
    kyfdxkyfdx Moderator Posts: 237,185
    Yes.. also, 2WD models seem to have lower residuals than the 4WD models..
    bxm22bxm22 Member Posts: 5
    edited October 2013
    Can you please post the MF and residual for a 2014 Citadel with AWD for 36 and 39 months with 15K miles? Many thanks!
    2014 Citadel AWD 36mo, 15K/yr
    .00050 MF and 45% residual.. 39 mo. residual is 44%
    regards,
    kyfdx
    Thanks! Its quite a difference compared to the Limited.
    bjessupbjessup Member Posts: 3
    Can you please post the MF and residual for a 2014 Durango SXT and Limited 2WD 36 months, 12k miles. Located in south Florida.
    2014 Durango SXT 2WD 36mo, 12K/yr lease (w/pkg 23B)
    .00033 and 50% residual
    The money factor on the Limited is .00039, and has the same residual
    These numbers are in effect through Monday, 11/04
    regards,
    kyfdx
    grmaroungrmaroun Member Posts: 1
    Kindly post current lease rate/residual for 2014 Dodge Durango R/T AWD 12k/15k mileage allowance
    -GM
    hedges1hedges1 Member Posts: 12
    Would also appreciate updated numbers for 2014 citadel, 15k 36 months. Rwd or awd
    2014 Dodge Durango R/T AWD 39mo, 15K/yr lease
    .00046 MF and 47% residual. Add 2% for 12K/yr
    regards,
    kyfdx
    2014 Dodge Durango Citadel AWD 36mo, 15K/yr lease
    .00074 MF and 44% residual
    regards,
    kyfdx
    azteco469azteco469 Member Posts: 11
    Can you please post the numbers for a 2014 Dodge Durango Limited AWD 24mo & 36mo 12k? Thank you.
    2014 Dodge Durango Limited AWD 36mo, 12K/yr lease
    .00039 MF and 47% residual
    27 month lease (The 24 month lease is not subsidized)
    .00037 MF and 58% residual
    regards,
    kyfdx
    dykastdykast Member Posts: 12
    Do you happen to have the December numbers for
    2014 Limited, R/T and Citadel
    12k/36m
    Thanks for the help
    2014 Durango Limited AWD 39mo, 12K/yr lease
    .00039 MF and 49% residual
    R/T AWD
    .00046 MF and 49% residual
    Citadel AWD
    .00074 MF and 45% residual
    I gave 39 month numbers because they are much better than the 36 month numbers on the Limited and R/T model (just a little better on the Citadel)
    regards,
    kyfdx
    gafonmvgafonmv Member Posts: 10
    Are the February MF and residual numbers available for
    2014 Limited, R/T and Citadel? 36mo or 39mo, 10k/yr lease
    Assuming AWD?
    Limited: .00039 MF and 53% residual for 36mo, 10K/yr
    R/T: .00025 MF and 52% residual
    Citadel: .00035 MF and 52%
    dewarsandsodadewarsandsoda Member Posts: 207
    What are the MF and RV for an R/T AWD and a Citadel AWD V8 for 24mo/12K? 27mo/12K?
    Cheers!
    Cheers!
    Citadel: .00047 MF and 61% residual for 24mo, 12K/yr. 27 month program is not good.
    R/T: .00030 MF and 62% residual for 24mo, 12K/yr.
    Kirstie_HKirstie_H Administrator Posts: 11,148
    Please continue in our 2014 Dodge Durango Lease Questions discussion
    MODERATOR /ADMINISTRATOR
    Share your vehicle reviews
