Is this for the front or rear of the carpet (not the mat)?
01r1, you can email some to skimblzbvs at yahoo dot com. My email in my profile is definitely not one to give out (it's my work/hispeed one).
-Paul
Glen
I meant to check my dimming mirror to help with your problem. I've only needed to turn it off once, and I too thought it was done by pressing both switches simultaneously. All that ended up turning on/off were the map lights. As for the other button, I thought that only turned off the temp/compass. Will check later.
Mac24, it's the driver's side, front floor mat clip. It catches the rear of the mat (closest to the seat). Hit it funny with my heel and SNAP!
Thanks all,
Mike
Hey, good to see you back with us! Sorry it has taken me this long to reply.
Glad you are hugging your Jeep! They need love and attention to function properly.
I agree with what Mac told you. City driving IS hard on an engine, so spending the extra bucks on more frequent oil changes is not a bad idea.
Also, like Mac said, city driving can be very hard on brakes too. It would help to allow lots of following distance and to slow down so that you give the traffic light time to go green and the stopped cars to get going again. Then you wouldn't even have to use your brakes, and you would catch up to the cars ahead anyway, so you wouldn't lose any time. Bet I know what would happen if you tried that: cars would come around you and cut back in front of you, taking away that space that you are trying to leave open in front of you, right?
Some people seem to think they need to be either heavy on the gas or heavy on the brake. They stay on the gas right up to the very last second as they approach a red light, then they jump on the brakes real hard to get stopped in time. It would make MUCH more sense to ease off the gas as they approach a red light, and maybe they could avoid using the brakes all together, if the light changes in time. At least they would not have to stand on the brakes to get stopped in time.
Oh well, just one of my pet peeves.
Stick around, Mike! Don't disappear on us again.
Tom
Have you hugged your Jeep today?
Gradual is a concept that REALLY extends the life of any vehicle. Sudden acceleration, braking, turning, etc all contribute, IMO, to faster wear. Sometimes is can't be avoided, but most of the time it can.
-Paul
I'm more sucessful with the 5 speed than I am with the auto, so I expect that I'll be replacing the brakes on the Unlimited sooner than when I did with either the Sport or the Taco (both 5 speeds). I'm really torn about which tranny I prefer - in some cases I really appreciate the auto, at other times I miss the engine braking you get with the 5 speed.
I know I get unusual mileage out of things like brakes and clutches because 98 percent of my driving is freeway (though it isn't always fast). If I lived in Santa Monica or Culver City I think I would go nuts - all those stop signs and lights! I'd rather drive 75 miles with 2 stop signs and 5 lights than 20 miles with 45 lights and 10 stop signs - it probably takes about the same amount of time. And Tom's way of easing up to things won't work as well under those conditions. By the way, this is one of those times when I wish I didn't have such a good job - I's love to be able to move...
Someone else suggested doing work like brake jobs on my own. Alas, I'm like Tom Cruise/Cole Trickle in "Days of Thunder." He could drive, but knew absolutley nothing about under the hood.
I'm curious about what invaldiates a warranty? Doing the work yourself? Going to a private mechanic? Etc.? Where in the paper work is that? I've got a mechanic I trust, but he works out of his home garage.
Mike
-Mike
A Haynes manual is a good start if you're not too technical, but want to learn more and do a few of the basics yourself. Using it, I was able to swap out my radiator easily. I've done all my mods myself, and when it comes time to lift my Jeep, I'll do that too.
You'll not only save some bucks, but learn a lot about your rig in the process. If you have a mechanical friend, have them watch you or help you, but do the work yourself so you can learn. I've found it is kinda fun too.
-Paul
I'm sure I did say (a couple of times) that the mats weren't listed, just the carpet, but in case we're confusing nomenclature I'll give the ones for the front and rear of the carpet for an '02 (latest I've got).
Rear part# J400 7545 QTY.2 SCREW AND WASHER, Snap Head, .164-18x.375
Front part# 6503 274 QTY.5 PLASTIC NUT, Push On
Though from the diagram it looks like it should be three rear fixings and two at the front (on the drivers side).
Still a happy camper.
Tom
Glen
In Internet Explorer it's under Tools, Internet Options, Advanced, and scroll down to the auto complete tick box. Firefox uses the auto:config function.
Then there's that Remember Me option when you log in here too.
How is RA?
No worries I picked up Norton’s password manager for free when I upgraded my “Norton Internet Security” program to 2005.
Glen
Remember also that larger wheels on a 4 cyl will have a deleterious effect on highway performance. You might want to give some consideration to re-gearing as well.
A tip I learned on this board; turn on the vent with the windows closed. It will make the rear windows expand and decrease the flapping by quite a bit. Pretty neat trick, give it a try.
-Dan
Ok, I give up. How do I end a bold command. I only intended to bold and italic the quote. But, it applied to the whole message.
edit...I have no idea how that just happened.
Closing tags are inserted at the end of your message should you forget to include them.
The next great innovation will be a neural interface so that all you'll have to do is think of what you'd like to say and it will appear on the screen! Of course that may complicate hosting somewhat as members express themselves without inhibition!
What would a Wrangler be like that responds directly to your wishes? :-)
I guess she's be about 5'10", 130lbs and ......... I think I'd better stop there!
Well you asked (actually I did once know a girl named Rangler, which is close enough).
-Paul
I enjoyed the afternoon more than our morning. The sight of a tree getting ever closer as the jeep slides sideways was not enjoyable. In the afternoon, we did more creek driving; up and down the banks in a few places, climbing over logs and rocks.
I've took quite a few good pictures but didn't get any of myself. There was one other person that had a digital camera, I know she took at least one picture of me; on our last climb up and out of the creek and jumping over a log that was laying at the top of the bank. I hope the picture is as good as it felt!
This was a lot more fun than the first time, when
the jeep was stock and high centered several times. one of the guys had a stock unlimited, he was having a problem with that too. The lift and tires has solved that problem for me.
jeff
Tom
I'm running essentially stock for now, but I see the letters "OME + 32's" calling me from the horizon!
-Paul
she was more understanding than i expected this weekend,, I told her I'd leave pike county (where we were wheeln') around noon, and be to her house around 3. there was no reception where we were, so I didn't get a chance to call her until i was finally leaving ~3.
I helped her dad work on the plumbing at her house, I guess i redeemed myself.
jeff
whaddya know, it works.
Thanks tidester
-Dan
Tom
